Water Coming InCabin - Passenger Side
TMedge01
I have a 2011 Ford Edge Limited
Just noticed water coming in the passenger side around the fan area when specifically making a left and turn. There's a swish sound when making a left hand turn...almost sounds like air being forced through the system then the water comes out.
I recently installed a K&N Cold Air intake system and had not noticed this issue previously ..although it could have existed.
Any one experience this before either in general or after installing a cold air intake system?
Is it clogged lines or censors causing the water build up and discharge?
Edited by TMedge01
thanks .. I'm stumped and not convinced the cold air intake is to blame although the swishing of air is suspect since the cold air intake filter is pointing to the left and the swishing / discharge of water occurs only on left hand turns. Is the a/c evap drain easy to service myself or is a dealer needed?
  • 1 year later...
