Life expectancy of keyless entry remote fob batteries?
What sort of life cycle do the batteries in the remote entry fob have? Is there any indication that they are on their "last legs" or do they just go dead? Do you keep spare batteries handy, or just replace them @ some specific time interval? If you do this, how often?
In.my last car, 5 years and 7 years. All depends on how much their used.
Don't buy battery ahead of time. They have a shelf life. If they go dead, you can still open the door using the key. (Remember when ...)?
On my 09 there is no indication when they're getting weak. Just wait till they don't work and replace.
  • 2 months later...
I have same question last 3 months
One off my key with fresh battery
Show me message battery need change
After 6 months use
I change and another month same message
Tech. Told don't keep key in packet
Now after one months same message again battery low
So considerate push dealer change key or problem with car
It is possible you're accidentally keeping the button pressed and that's draining the battery. It could also be a bad fob. Do you keep the fob in the car?
Try carrying the other fob and see if it does the same thing. If it does then it's probably you. If not then the fob is probably defective.
You can also put a new battery in the original fob and leave it somewhere for a month or two and see if the battery is dead. That would confirm the fob is bad.
  • 4 weeks later...
My 2013 Edge Limited fob battery lasted almost 4 years with mid to moderate usage. Car would not start with low/bad fob battery due to no signal to anti-theft receiver in steering column. Turn key on steering column and no engine cranking. Changed out battery and worked fine since then (6 weeks ago). No indication on the dashboard panel that fob needed new battery. Takes one 2032 battery and battery is easy to change in fob.
The fob can drain the battery. I had that happen on my 2012 Toyota Rav4 I just replaced with the Edge.
One original fob was going through batteries every two weeks. I had used Maxell bought on Amazon and thought that could be the problem. I then bought Energizer and Duracell retail at Walgreen's and the problem was the same.
Switched to a fob I had bought on eBay and haven't changed the battery in months, until I got the Edge.
