I've been using Zaino Z-2 for the past 10 years. Awesome product!!!! Extremely easy to apply and lasts longer then anything else I've ever tried. That said, I just picked up some Duragloss 105 to try. Not sure about the durability of the 105 yet but it is much more difficult to apply. Gonna give the 105 to my brother and stick with Z-2.
The best I've used, and continue to use, is Klasse All-in-one (in combination with Klasse Sealant, if you want to get fancy).
I've also got decent results from Meguiar's NXT Tech Wax, which is easier to come across and a little cheaper than Klasse, I think.
edit: you can get all of these on Amazon:
Klasse AIO
Klasse Sealant
Meguiar's NXT (you can most likely get this locally too)
Edited by mrdave
Mr dave,
I use and do like Meguiars NXT. I usually out that on and then once buffed in good I will use the Meguiars Ultimate paste wax on top because it will buff out like glass because it has good carnauba in it. I like to hear what other people are doing though. Thanks for the reply. I'll look at the Klasse products.
Klasse AIO
Klasse Sealant
I am a big fan of NXT as well. Is that all I need from the start or should I use something else. My Edge should be in my hands any day now i am just planning on getting a good coat on ASAP just not sure which route to go (paint sealent or just NXT), I do like the reflectivity of NXT and think that will be important for deep impact blue
NXT is a decent synthetic product but it does not last very long if you are a frequent washer. If you wax 4-5 times a year, NXT would work just fine. If you only wax once or twice each year or live in a northern climate, I would look into a more durable product. I tested NXT against Z2 many moons ago by doing half the hood of my 2003 F150 with each product just before the Michigan winter. The Z2 outlasted the NXT by a longshot. My leftover NXT keeps my ATV nice and shiney!!!!
Isn't Zaino Z-2 is a polish, not a wax?
Not sure why, but Zaino calls the Z-2 a "Show car polish". Both Zaino and Duragloss use the term polish for their wax/sealents even when they contain zero abrasives. The Z-2 Pro does not contain any abrasives so it has no cleaning ability and can be layered. I'm the farthest thing from an expert so maybe someone else can chime in and explain why these companies call there products polishes. I've always associated the term with polishing compound which I don't think I'd use on a new car 5 times a year!!!!!!
I just finished washing, polishing and waxing my Edge. I've never polished before, so I thought why not now. I can't tell if it helped, but it sure makes my arms stronger. I used the NXT wax, and we'll see how long it lasts. I also applied Rain-X to all the glass. The weather tried to rain on me after I dried the car, so I had to dry it again, but it stayed cloudy most of the afternoon, so nothing got baked on.
Cdpratt: I have used the Klasse products since 2001 and have not looked back. Over the years, I have used the following:
Klasse AIO (All In One) and SG (Sealant Glaze) plus the following items:
- Pinnacle Souveran Wax (Highest gloss with darker colored cars)
- S100 Wax (Essentially the same as the P21S, but cheaper and can be bought at any Harley store)
- P21S Wax
I have used Klasse AIO and Autoglym's Resin Sealant and topped that with Pinnacle Souveran on a Black Maxima and that rig was shinier than Darth Vader's helmet....literally.
Pic of my wife's former Neon before and after the following:
1Z Bug and Tar Remover
Sonus Rim Bright
303 Carpet and Upholstery Cleaner (Works well on vinyl)
Sonus Vision Glass Cleaner
PC 7336 @ 5
SFX Yellow Cutting Pad
Lexol Vinylex
Meguiar's Dual Action Cleaner Polish
Sonus Block Clay (Sole Casualty)
Sonus Glyde Lubricant
Meguiar's Scratch-X (Removed scratches on the rear quarter of the car)
Sonus Der Wunder Mitt
Sonus Wool Mitt
2 HP Shop Vac
Blue Perl Microfiber Applicator (Cleaned Vinyl with it)
Stoners Invisible Glass
Meguiar's Plast-X (To try and remove the crap on the headlights)
Pinnacle Souveran
Before:
After:
Edited by PrinzII
  • 4 months later...
I've been using the Zaino system for 10+ years now - I've tried some other products along the way, and no doubt there are some excellent other systems out there, but Z works for me and so I keep going back to it. Some reflection shots of a couple darker colour cars I've owned (Z does seem to work best on dark colours)...
Edited by Scorpio
