Custom Search
* * * * * 4 votes
PTU Leak / Failures
  • Please log in to reply
597 replies to this topic
#581 1004ron
1004ron
    New Edge Member
  • Edge Member
  • 298 posts
  • Region:Decline
  • Edge's Year:2017
Posted 01 May 2018 - 09:16 PM
My new dealer
If it were me, I'd suffer the inconvenience and find another "new" dealer.
To the left of the top circle it looks like they rounded a nut.
#582 Tightanium
Tightanium
    New Edge Member
  • Edge Member
  • 110 posts
  • Region:Decline
  • Edge's Year:2016
Posted 28 May 2018 - 01:47 PM
The Sport had the only CONFIRMED drain plug at that time, the others also are now confirmed.
I have a 2016 Tightanium 3.5. It does have a drain plug. The fill plug has a magnet on it also. The dirty plug has lots of metal on it.
Edited by Tightanium, 28 May 2018 - 03:38 PM.
#583 1004ron
1004ron
    New Edge Member
  • Edge Member
  • 298 posts
  • Region:Decline
  • Edge's Year:2017
Posted 28 May 2018 - 02:11 PM
I'm pretty sure that only my drain plug has a magnet.
Good to hear that all models now have drain plugs - wonder if Ford is still claiming them to be lubricated for life.
#584 Tightanium
Tightanium
    New Edge Member
  • Edge Member
  • 110 posts
  • Region:Decline
  • Edge's Year:2016
Posted 28 May 2018 - 03:25 PM
Attached File  3FBEE9EA-79E8-4FD1-BF6D-6FF980453C9B.jpeg   1.18MB   0 downloads
Attached File  7F84584A-4838-4908-BA10-7AED043D53C3.jpeg   755.76KB   0 downloads
The small plug near bottom is a drain plug.
#585 Tightanium
Tightanium
    New Edge Member
  • Edge Member
  • 110 posts
  • Region:Decline
  • Edge's Year:2016
Posted 28 May 2018 - 03:31 PM
A little more then 11oz came out. In my opinion the fluid was ok at almost 28k miles. On my car its not to hard to do so no big deal to do it every 30k. But it probably would last longer. The size difference of plugs also.
#586 1004ron
1004ron
    New Edge Member
  • Edge Member
  • 298 posts
  • Region:Decline
  • Edge's Year:2017
Posted 28 May 2018 - 04:08 PM
Your oil looks better than mine did at 5K and 15K, and sure doesn't look like it was in need of a change.
Your PTU looks different to mine and to @JSchneid
His casing looks very different and his plugs are the same type of torx T50 as mine, with the drain on the underside.
Odd that there's all this variation.
Edited by 1004ron, 28 May 2018 - 04:08 PM.
#587 Tightanium
Tightanium
    New Edge Member
  • Edge Member
  • 110 posts
  • Region:Decline
  • Edge's Year:2016
Posted 28 May 2018 - 04:25 PM
I was surprised how good it looked also. Maybe build date or plant has something to do with the different ptu’s
4/16 Oakville plant is mine.
#588 Jstin
Jstin
    New Edge Member
  • Edge Member
  • 2 posts
  • Region:U.S. Great Lakes
  • Edge's Year:2014
Posted 13 June 2018 - 09:09 PM
I have AWD, had the PTU replaced last year under extended warranty. Also have the lubricant changed by local dealer every 30k. (Although I haven't changed it since it was replaced).
Is this on your 2009? How is dealer changing the lubricant?
#589 enigma-2
enigma-2
    Ford Edge Fanatic
  • Edge Member
  • 3,193 posts
  • Edge's Year:2009
Posted 14 June 2018 - 08:34 PM
Told me they use the same machine to change the lubricant in the PTU as they use for differentials. Apparently it can both suck out the old and pump in the new.
note: he made me feel as if it was a common piece of equipment in any Ford service shop.
Edited by enigma-2, 14 June 2018 - 08:35 PM.
  • WWWPerfA_ZN0W and onyxbfly like this
#590 ManiN
ManiN
    New Edge Member
  • Edge Member
  • 3 posts
  • Region:Decline
  • Edge's Year:2013
Posted 25 June 2018 - 09:10 AM
Hi All, thought I'd post my applied fixes to this same problem.
Have a 2013 Edge with classic leaky PTU leaving splats of black oil on the garage floor with also the burning of the same oil splats on the exhaust crossing under the output shaft from the PTU.
I've read through many forums related to this issue in various forms and finally built up the courage to apply some of the methods to get past this issue.  One important one being to add a drain for oil changes, but I also wanted to deal with the belching breather.  In another forum I noticed on the focus, ford actually provides a kit to extend the breather into the engine bay by way of removing the old jiggly cap breather and putting this kit on that has a barbed insert, hose, and breather cap.  Specifically the kit is AG1Z-7034-A. (forum I found this info: https://www.ecoboost...hp?topic=6849.0)
I couldn't find any documented application of this kit to an Edge, but I did find someone with an Explorer put this on.  Before purchasing, I thought I'd get under and feel it out to see if it were even possible.  Glad I did because it isn't really possible to do that kit on the Edge without removal of the PTU.  There just isn't enough room to remove the breather and tap in the barbed nipple for the extension hose.  However, there's still a solution if you're motivated...
The jiggle cap breather is already installed, so I took a risk and knew that if I could remove the cap (blindly by reaching up through and over and just feeling it out), I could pull out the rubber check valve within and thus converting the vent into a nipple to put a hose on.  I was ultimately successful by using a socket and shorty 3/8 ratchet.  I slipped the socket over the jiggle cap and pulled to the side and rotating the ratchet.  This essentially flared the jiggle cap open and after a bit of fighting I got the cap off.  Next I fought the rubber check valve a bit, but in hindsight, just use a pick and it should just pull out easy.
At this point you'll have a "nipple" to put some 3/8 hose on.  The breather body dia. is somewhere just under 1/2".  I was able to slip the hose over with a clamp to secure it.  At that point you can secure the top of the hose to the wiring next to the master cylinder up top.  You'll need to find a breather online to put in the end of the hose.  Something like a Toyota 90930-03136 or Dorman 924-284 Axle Vent.  I just found this online, but as long as it is designed to breathe / vent outward, you should be ok.  Even just a filtered vent would be fine.  Just make sure it fits your hose.  Of course you could buy the $75 kit for the focus mentioned above, but I cannot verify if that hose will fit the modified jiggle cap breather converted to nipple.
After this vent tube was installed, I drilled the drain and tapped a 1/8-27 NPT plug.  I was able to drain the fluid and simply grab my royal purple bottle and just squirt it into the vent tube.  Soooo easy.... Once it was dripping from the plug in the side (original fill location), I stopped adding fluid and buttoned everything up.
All in all I'm glad i have a full solution to this problem now.  I'll update with results, but having ready all of the success in both of these mods, I am sure I'll be able to share the same results.
End comments: It may seem a little ghetto to mod the jiggle breather like that, but I assure you, unless you want to drop your PTU to do this, it's impossible to pull and replace that breather with something where it is located otherwise.  And unfortunately, I didn't take pics, but there is enough documentation related, you can navigate your way through this without them.
Edited by ManiN, 25 June 2018 - 09:47 AM.
  • WWWPerfA_ZN0W likes this
#591 ManiN
ManiN
    New Edge Member
  • Edge Member
  • 3 posts
  • Region:Decline
  • Edge's Year:2013
Posted 11 July 2018 - 09:09 AM
So far so good with my fix.  Had a drip the next day but nothing after that.  I'm suspicious that filling to the side fill plug is slightly over full as mentioned by others.  There are no drips now and no heavy smells.  There is still a slight odor in the garage ,but I also wasn't able to fully clean the PTU top side and even just this can cause odor.
#592 WWWPerfA_ZN0W
WWWPerfA_ZN0W
    Ford Edge Legal Resident
  • Edge Platinum Member
  • 8,934 posts
  • Region:U.S. Northeast
  • Edge's Year:Decline
Posted 12 July 2018 - 05:12 AM
Hopefully you will be set for some time.  What are your driving conditions normally like?  All highway 30K, all city 10K mile intervals for fluid changes.  Time to do the RDU as well at every other PTU fluid change.
#593 1004ron
1004ron
    New Edge Member
  • Edge Member
  • 298 posts
  • Region:Decline
  • Edge's Year:2017
Posted 12 July 2018 - 05:37 AM
What was your fix?
#594 WWWPerfA_ZN0W
WWWPerfA_ZN0W
  • 8,934 posts
Posted 12 July 2018 - 05:41 AM
http://www.fordedgef...-30#entry187041
#595 1004ron
1004ron
    New Edge Member
  • Edge Member
  • 298 posts
  • Region:Decline
  • Edge's Year:2017
Posted 12 July 2018 - 05:44 AM
Thanks, looks like we have exposed another defect with the recent forum "upgrade", I responded to the post with that question based on his post count showing "1 posts", whereas he does have additional posts.
#596 ManiN
ManiN
    New Edge Member
  • Edge Member
  • 3 posts
  • Region:Decline
  • Edge's Year:2013
Posted 12 July 2018 - 11:09 AM
Yes, I noticed this and wondered why no one replied to the thread.  My guess is that it didn't even bump the thread to the list until I posted my follow up.
#597 ManiN
ManiN
    New Edge Member
  • Edge Member
  • 3 posts
  • Region:Decline
  • Edge's Year:2013
Posted 12 July 2018 - 11:52 AM
This is now common too?  Wouldn't have thought it was as bad being in the rear away from a heat source.
From my digging and personal experience with my PTU, the fluid becoming grease like I believe is from a vastly over heated PTU.  I've seen others mention this theory in their posts, and I agree.  At work we had Mobil Oil come in to discuss their fluids.  We spent time discussing how lubricant can be damaged and improperly applied in applications.  One point I remember was overheating and how it can damage the lubricant changing it on a molecular level.  One failure of lubricant is thickening (not change in viscosity).  This is exactly what we see here is the lube getting overheated and becoming grease-like.  Unfortunately when it's degraded like this, the lubricant properties are drastically reduced and you will have early wear on components.  That said I believe the real root of the problem with these PTUs is running the cat & exhaust basically wrapping around it.  Cooking the oil like a vat of hot tar...
Some folks have added more home made heat shields to protect the PTU.  I think this is a good attempt, I'd imagine it would at least buy some time between changes.
These same points above are the reason to buy more expensive higher heat rated lube if you can.  I personally chose Royal Purple.  I think between higher quality lubricant and routine changes, this is the only way to help it along unless you reroute the exhaust (not happening).
Edited by ManiN, 12 July 2018 - 11:53 AM.
#598 WWWPerfA_ZN0W
WWWPerfA_ZN0W
  • 8,934 posts
Posted 14 July 2018 - 06:02 AM
The RDU has far fewer issues, but they will occur.  And since it is also far easier to change, why not.  If you have the original RDU fluid, breakin metals are not doing the unit any favors.
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
