Snow Tires?
Mirage52
Hello.
I have a FWD '13 Edge. Just bought it and it handled well in the snow we received last night. But when the tires start to get worn, I wonder about its ability to handle itself in snow.
I've never bought snow tires before, so I was wondering -- would I need 4 snow tires? Or just 2 for the front wheels?
Also, would I need a shop to put them on and take them off whenever I needed them? Or is there a way to have them set on an extra wheel so I can do it myself according to the forecast? Of course that would require me to buy 2 extra wheel rims.
Any advice would be great. Thanks.
I use Blizzaks on all four wheels and usually the tire store you purchase them from will discount the remounting and mounting (less than 90 dollars) The traction you get from dedicated snow tires makes a world of difference in the snow. I tried just two front snow tires and rear end was everywhere. I usally get two seasons out of a set of snow tires, if you drive less miles than my 60k a year they should last you even longer. Don't install them until temp below 50 on road surface on average and take them off once you feel the potential for snow is over.
Thanks for the replies. I am also looking at snow chains/cables. I really just need something in case of a bad storm, to get to and from work, which is 8 miles away. I know 30 mph is the max speed for snow chains but I don't have a garage to store snow tires and here in MD I don't know if it snows enough to warrant spending the money for them and then paying to have them put on and taken off each year.
Any advice?
Skinny tires are better in the snow.
The 20" Pirelli tires that come stock on the limited are junk in packed snow. Ours has 15,000 mi. (So don't tell me it's because there worn).
I'm looking for a set of rims to mount blizzak winter tires on for winter. That should help, though if I could do it again, I would've bought the AWD.
  • 10 months later...
I know this is old post, but to help others on the 20" wheels you can use SCC Super Z6 SZ435 or the Z-575 with no problems. There is plenty of clearance to fit them and the Z-575 don't touch the wheel if you're worried about scratching the wheels. I've driven a few hundred miles in Big Bear with them this season, and they work great with no problems.
Before anyone wants to bash me for using them, if you don't know they are required to even go up the mountain when anysnow or ice is present. Put them on the front by the way.
Skinny tires on snow is an interesting comment as well, and for the most part incorrect. Snow driving boils down to tires, not what car you drive although AWD can help but only as much as the tires allow it to. The stock pirellis weren't built for snow, but an all around tire, so they will suffer after the tread wears down a bit.
I asked for some tire socks from AutoSock.com for Christmas. Anyone tried these before? From the reviews I read it sounds like they work well but wear out pretty quickly. Speeds top out at 30 MPH so they'll only be used in heavy snow conditions. So far the winter in MD has been pretty mild. My FWD handled fine in the snow last year -- and we got a ton. Figures. But I needed something to put on my Christmas list so I figured what the heck.
