Left rear turn sig/brake light not working
Like many owners, I've had both of the rear turn signal sockets burn due to piss poor design. I've replaced both.
Now my left rear/brake light isn't working. I've switched the light sockets AND I've replaced the connector. And then switched out the sockets.
Still no go.
Is this a known issue? If so, is it something that can be fixed at home or does it require a shop's raping?
Did you check the CHMSL? Sometimes the wiring is connected.
I looked up CHMSL--that's the center light, right? It's connected and works. What else should I look for?
Oh, and on the asking part. I understand completely!
Edited by jbswear
I just realized that I forgot to mention a very important bit of information: The running light on that socket works, but the turn/brake signal does not. The front left turn signal works.
Does this make a difference? There is power to the socket.
Is it the same bulb? If so then make sure you have the right bulb with 2 filaments (I'd verify the part number and replace it just to be safe). Otherwise check both wires for power at the socket.
Yup. Same bulb. I can put it into the right side socket and it works, both brake/turn and running light. Put it in the left socket and only the running light works.
I'll break out the multimeter.
