Custom Search
Sign In  Log in with Facebook
Create Account
Click here to signup now
Guest Message by DevFuse
The Ford Edge ST Has Been Unveiled.  More here.
Reverse cam woes
  • Please log in to reply
115 replies to this topic
#101 OFFLINE   WWWPerfA_ZN0W
WWWPerfA_ZN0W
    Ford Edge Legal Resident
  • Edge Platinum Member
  • 8,392 posts
  • Region:U.S. Northeast
  • Edge's Year:Decline
Posted 12 September 2017 - 05:21 PM
This is an aftermarket brand, somewhat misleading with their name.  Usually I look to the section about item specifics that provides the info I want
For example
Item specifics
Condition: New
Brand: no.1-oem
UPC: Does not apply
Manufacturer Part Number: BT4T-19G490-AF
Warranty: Yes
Quantity: 1 pcs
Re: 08-23
Other Part Number: BT4T19G490AF;BT4Z-19G490-B;BT4Z19G490B;BT4Z-19G490-A;BT4Z19G490A
Might be just me. but the machining of Ford parts plastic is a lot better than shown in the accompanying pics for this item.
Edited by WWWPerfA_ZN0W, 12 September 2017 - 05:24 PM.
#102 OFFLINE   pcameron01
pcameron01
    New Edge Member
  • Edge Member
  • 4 posts
  • Edge's Year:2011
Posted 30 September 2017 - 04:53 PM
I just replaced my camera with ease thanks to everyone here. I installed the replacement camera i bougth off eBay for $50.
The image is upside down. The part number on the replacement camera i have is BT4T-19G490-AF. Im sure for $50 it is not a ford oem part of course. The only difference i see is my original ends with a E instead of the F. Obviously this isnt going to work can someone point me in the right direction where i could get a camera that will work besides going to ford for it?  A link a ebay store, im just not sure what to get i dont want to have to ship another one back. Thank you in advance.
#103 OFFLINE   tiguanito
tiguanito
    New Edge Member
  • Edge Member
  • 4 posts
  • Region:U.S. Pacific Coast
  • Edge's Year:2012
Posted 30 September 2017 - 06:34 PM
Same issue with the first camera I bought on ebay, image upside down and no calibration possible. I have returned it and bought this one : http://www.ebay.com/itm/FORD-OEM-11-12-Edge-Rear-View-Backup-Back-Up-Camera-BT4Z19G490B/162171150605
More expensive but is OEM, and works perfectly fine on my 2012 Edge.
  • WWWPerfA_ZN0W likes this
#104 OFFLINE   pcameron01
pcameron01
    New Edge Member
  • Edge Member
  • 4 posts
  • Edge's Year:2011
Posted 01 October 2017 - 10:59 AM
Wow yes definitely a big change from the $50. but you get what you pay for. Its weird ever since i put my original cam back in it works everytime i switch to reverse. Of course no lines anymore. I might see if it will stay working and program with forscan when iget the cable. I greatly appreciate the info on the camera. Its a shame there isnt a cheaper alternative.Thank you.
#105 OFFLINE   enigma-2
enigma-2
    Ford Edge Fanatic
  • Edge Member
  • 2,622 posts
  • Region:U.S. Great Lakes
  • Edge's Year:2009
Posted 01 October 2017 - 12:08 PM
Have you tried turning them back on?
> Menu > Vehicle > Rear View Camera
The fixed guideline options are ON and OFF.
#106 OFFLINE   Jayrodd_C
Jayrodd_C
    New Edge Member
  • Edge Member
  • 1 posts
  • Edge's Year:2012
Posted 02 October 2017 - 02:08 AM
In my 2012 sport, the fixed guidelines are (normally) always there, there is no option to turn them on and off, only the advanced park aid(colored blocks) and camera delay.
I've been having this same issue, bought a bluetooth obII scanner(the one wlepse linked in his thread on the matter) hoping a recalibration would fix it.
recalibrating fixes it temporarily, but the guidelines disappear again after a while. For example, if I were to recalibrate in the evening, they would stay for a couple short trips and when I park for the night(I back into my spot), but be gone again in the morning.
I'm thinking my next step will be to replace the camera to regain 100% function(I like having the guidelines and colored blocks), but would rather not have to pay the crazy prices these things are going for.
Didn't somebody mention somewhere on this forum that they bought one for an explorer or something for pretty cheap and everything worked after a calibration with forscan?
#107 OFFLINE   pcameron01
pcameron01
    New Edge Member
  • Edge Member
  • 4 posts
  • Edge's Year:2011
Posted 06 October 2017 - 03:41 PM
I tried to do everthing but nothing changes. Now with the factory cam back i am getting the see dealer notice once in a while still.
I just ordered another off ebay to try. Im sure its a china knockoff. It has a different part number. I will post any changes if any.
Edited by pcameron01, 06 October 2017 - 03:43 PM.
#108 OFFLINE   Bryan Hudgens
Bryan Hudgens
    New Edge Member
  • Facebook Member
  • 2 posts
  • Region:Decline
  • Edge's Year:2012
Posted 07 October 2017 - 07:41 PM
For anyone that is having camera issues and wants to swap out the camera (if thats the defective part) here is what I did to get the camera out.
First remove the 4 screws in the hand grip area of the lift gate.
Next pop off the big interior panel. Kinda have to tug a bit but is will come off.
locate the 6 nuts across the back of the trim piece and remove.
Now find the the 2 plastic push clips on either end of that row of nuts. Squeeze with a  needle nose and push out.
Undo the small black wire connector and the flat grey one.
I popped out the plate lights and wire harness prior to any of this..
Now that its off the ONLY way to get the camera out is to remove bracket holding it down....this is tricky.
This is the bracket.
It has one star head screw holding it in.
You will see the back of it in that hole.
Getting to the front will only happen with tiny tools. OR...you can do what I did and Dremel a slit in the tip of the screw and use a tiny flat head to back it out.
No guts no glory LOL
I reassembled in reverse order..camera/ bracket/ screw(if for some reason you royally screw up in removal I suggest a very small nut and bolt combo to reattach the bracket) wire harness/ lights....
So one thing I noticed when ordering a new camera is that there is 2 listed a older dated one and and a newer one. Im going to try the newer one and see what happens.  I base this fix souly on reading other forums and people having this issue fixed at the dealer, stating that the fix was replacing the camera and reprograming it to get the guide lines working.
DISCLAIMER: I take no responsibility for anyone who screws their car up. Attempt at your own risk!
Thanks for the helpful instructions.  Ford Dealer wanted over $1000 to replace the camera.  Thanks to these steps I was able to do it on my own in just a couple of hours.  Yes, that screw is a beast to get out.  My neighbors and I thought we could try several things that might work, but ultimately I used the Dremel to create the notch and reversed it out.  Replaced it with a rivet so that if I ever have to do it again I can just drill out the rivet, but hopefully the replacement camera will last longer than the vehicle.  No grid lines like others said.  Factory reset and such doesn't do anything.  I am curious if anyone has any recommendations on a DIY reprogram for the grid lines, and/or if you have taken it to the dealer for just the gridlines and how much that was, and what the experience was?  Thanks again to the community and all the great tips for helping save me a lot of $$$.  My wife is happy that she can see when she backs up now using her camera.  Seems to me that as many people as there are having this problem, Ford would fix this and do a recall or something, but oh well..  Such is life.
#109 OFFLINE   Bryan Hudgens
Bryan Hudgens
    New Edge Member
  • Facebook Member
  • 2 posts
  • Region:Decline
  • Edge's Year:2012
Posted 07 October 2017 - 07:43 PM
#110 OFFLINE   omar302
omar302
    Ford Edge Addict
  • 1,715 posts
  • Region:Middle East
  • Edge's Year:2011
Posted 07 October 2017 - 10:57 PM
Using ForScan with a compatible adapter you can re-program the camera yourself.
#111 OFFLINE   pcameron01
pcameron01
    New Edge Member
  • Edge Member
  • 4 posts
  • Edge's Year:2011
Posted 13 October 2017 - 09:37 AM
Well i received another camera from ebay, installed and same issue reversed image.
Installed original and reprogrammed the lines.
Worked for a day. Looks like i will have to bite the bullet and order the $200 one.
Bryan as said above you can reprogram the factory lines on it with a usb to OBD cable and a free program called Forscan. You can youtube a video on how to do it. It takes minutes to do. Dealer wants $80 just for the reprogramming.
Edited by pcameron01, 13 October 2017 - 09:39 AM.
#112 OFFLINE   WWWPerfA_ZN0W
WWWPerfA_ZN0W
  • 8,392 posts
Posted 27 November 2017 - 12:23 PM
Anyone run into this error using Forscan for Windows EL?  Trying to recalibrate a new Ford camera
Attached File  Camera Calibration Error.jpg   114.88KB   0 downloads
#113 OFFLINE   candurin
candurin
    Ford Edge Enthusiast
  • Edge Member
  • 1,080 posts
  • Region:Decline
Posted 27 November 2017 - 12:36 PM
Did you get the camera from ford or was it a 3rd party (e.g. eBay) camera?
I ask because ForScan has notoriously had issues with completing the calibration routine with non-OEM replacement cameras.
If you look at the DTCs, so you have a B115E:08-48 error?
#114 OFFLINE   WWWPerfA_ZN0W
WWWPerfA_ZN0W
  • 8,392 posts
Posted 27 November 2017 - 03:54 PM
From an eBay seller selling Ford parts.  No DTCs to report :(
#115 OFFLINE   candurin
candurin
  • Edge Member
  • 1,080 posts
  • Region:Decline
Posted 27 November 2017 - 04:10 PM
Hmm... If it's a knockoff, then perhaps that can be the issue.  From what I read on the FORScan forum, it's not a FORScan issue (at least they are not willing to take any blame).
http://www.forscan.o....php?f=6&t=4408
Edited by candurin, 27 November 2017 - 04:11 PM.
#116 OFFLINE   WWWPerfA_ZN0W
WWWPerfA_ZN0W
  • 8,392 posts
Posted 27 November 2017 - 07:56 PM
Good info!  I will dig into the hardware end, see if I can verify the camera manufacturer.
