Information screen
enigma-2
I'm having the hardest time seeing my instrument readout in my 09 MKX during daylight hours. Been that way since I bought it. Is this item supposed to be backlit when the headlights are off (I have my DRL's turned on, but that doesn't make any difference.)
Edited by enigma-2
Did you try the Dimmer Panel Switch or re-calibrating it?
From the Owners Manual:
PANEL DIMMER CONTROL
Use to adjust the brightness of the instrument panel and all applicable switches in the vehicle during headlamp and parking lamp operation.
Move the control to the full upright position, past detent, to turn on the interior lamps.
Certain displays like the message center and the climate control unit do not change with the dimmer control till the dash-mounted sensor senses full night conditions.
Note: If the battery is disconnected, discharged, or a new battery is installed, the dimmer switch requires re-calibration. Rotate the dimmer switch from the full dim position to the full Dome/ON position to reset.
This will ensure that your displays are visible under all lighting conditions.
