Custom Search
Sign In  Log in with Facebook
Create Account
Click here to signup now
Guest Message by DevFuse
The official Ford authorized Ford Edge Registry is now live. More here!
* * * * * 1 votes
Double Edged
2011 Ford Edge Limiited comparison High mileage Low mileage DIY
  • Please log in to reply
636 replies to this topic
#621 OFFLINE   macbwt
macbwt
    Ford Edge Fanatic
  • Edge Platinum Member
  • 2,411 posts
  • Region:U.S. Mississippi Valley
  • Edge's Year:2011
Posted 29 May 2017 - 07:08 PM
What does the MAF sensor do?  More than you think.  A lot of engine management and transmission management centers around MAF sensor data.
  • WWWPerfA_ZN0W likes this
#622 ONLINE   WWWPerfA_ZN0W
WWWPerfA_ZN0W
    Ford Edge Legal Resident
  • 7,748 posts
  • Region:U.S. Northeast
  • Edge's Year:Decline
Posted 29 May 2017 - 08:17 PM
Powertrain control at its' finest!
  • macbwt likes this
#623 OFFLINE   macbwt
macbwt
    Ford Edge Fanatic
  • 2,411 posts
  • Edge's Year:2011
Posted 10 June 2017 - 10:38 AM
Part one and not of my Edge's water pumps but donated pumps that had failed.  part two will examine the failure points.
#624 OFFLINE   macbwt
macbwt
    Ford Edge Fanatic
  • 2,411 posts
  • Edge's Year:2011
Posted 10 June 2017 - 10:43 AM
Lullubelle is starting to show some age and rear hatch lower seam rust is developing.  Going to happen in salt exposed roads and winter driving
#625 OFFLINE   lildisco
lildisco
    New Edge Member
  • Edge Member
  • 212 posts
  • Region:U.S. Great Lakes
  • Edge's Year:2016
Posted 10 June 2017 - 10:52 AM
Get yourself some fluid film. Should prevent it from spreading more
http://www.fluid-fil...e-applications/
I've been using it for years to prevent rust. The stuff works wonders. My work vehicles gets sprayed once a year & there's very little signs of rust, most likely developed prior to applying Fluid Film. Every time i work on any of our vehicles, i apply fluid film. Kinda like preventative maintenance.
Here's a video that i really like that shows exactly what fluid film can do:
  • factor99, WWWPerfA_ZN0W and macbwt like this
#626 OFFLINE   fishx65
fishx65
    Ford Edge Enthusiast
  • Edge Member
  • 662 posts
Posted 13 June 2017 - 09:24 PM
Mac, my 2011's front suspension is starting to knock a little while going over bumps.  I already did the swaybar links.  What usually goes first up front???  Just hit 90 Grand.
  • macbwt likes this
#627 OFFLINE   macbwt
macbwt
    Ford Edge Fanatic
  • 2,411 posts
  • Edge's Year:2011
Posted 14 June 2017 - 12:23 AM
Gosh,  I am at 200,000 just about.   Only suspension work I have done to my Edge is new struts and strut bearing mounts.   Check those and ball joints.
#628 OFFLINE   macbwt
macbwt
    Ford Edge Fanatic
  • 2,411 posts
  • Edge's Year:2011
Posted 17 June 2017 - 11:12 AM
And part two of the water pump video dissection.
#629 OFFLINE   macbwt
macbwt
    Ford Edge Fanatic
  • 2,411 posts
  • Edge's Year:2011
Posted 17 June 2017 - 11:16 AM
After about 8 times around the circumference of the earth and just 40K miles short of a one way trip to the moon. My Edge LU has now developed wheel bearing failure.  Not exactly sure which wheel(s) but I will let it ride just a bit longer to make it easier to determine the failed wheel then if it is the back I will replace both rears and so on.  Either way I will be replacing ALL four wheel bearings shortly. Now just to decided do I go with OEM motorcraft, SKF, Timken or Moog  so many decisions.
#630 ONLINE   WWWPerfA_ZN0W
WWWPerfA_ZN0W
  • 7,748 posts
Posted 17 June 2017 - 01:35 PM
Wow, the moon is REALLY close.  I hope it doesn't fall out of the sky someday.  LOL.
  • macbwt likes this
#631 OFFLINE   macbwt
macbwt
    Ford Edge Fanatic
  • 2,411 posts
  • Edge's Year:2011
Posted 22 June 2017 - 07:17 PM
The Ford Edge Easter Egg.  Have fun.
  • WWWPerfA_ZN0W and omar302 like this
#632 OFFLINE   macbwt
macbwt
    Ford Edge Fanatic
  • 2,411 posts
  • Edge's Year:2011
Posted 03 July 2017 - 04:59 PM
The infamous washer jet assembly replacement on my wife's Ford Edge.
#633 OFFLINE   macbwt
macbwt
    Ford Edge Fanatic
  • 2,411 posts
  • Edge's Year:2011
Posted 14 July 2017 - 11:36 AM
Long term effort to test oils with the duratec 3.5.
I have ran various oils to date through my 3.5 Duratec on both of my 2011 Edge's.
I am now changing the oil brand for the 5th time.  I have ran a synblend bulk oil initially with bulk filter then changed to a AMSOIL with AMSOIL filter for multiple runs with the 0W20 and now I am using Mobile one with AMSOIL filter.
I am now going to the the Purolator Boss oil filter and REDLINE 5W20 synthetic motor oil.
I have testing from many of this oils under two entirely different extremes.  1) all city high idle time and 2) all interstate mileage.
I run the same oils during the phase of the testing for Each brand
The All city Edge is ran for 100 hrs and the All highway is ran for 200hrs
Results so far have me against using 0W20 weight oil for any 3.5 for two reasons;  1)  Bearing and high metals wear the oil is just too light for hard use  2) Highway use the extended drive hours (200) the Duratec consumes the oil through the PCV system and will use over a quart of oil during a 200 hr run.
Currently I have mobile one and have lost just over half a quart in the 200hrs and the 100hr engine seem to be just slightly down at nearly 100hrs.   Testing samples will be collected soon
My goal is to build a data base of use in hours and type of oil my weight and brand and hopefully show how the oils behave with the 3.5 duratec.
Edited by macbwt, 14 July 2017 - 11:39 AM.
#634 OFFLINE   enigma-2
enigma-2
    Ford Edge Fanatic
  • Edge Member
  • 2,096 posts
  • Edge's Year:2009
Posted 16 July 2017 - 09:55 PM
Great experiment. Consider adding Motorcraft blend as the Ford dealers now use.
  • WWWPerfA_ZN0W and macbwt like this
#635 OFFLINE   macbwt
macbwt
    Ford Edge Fanatic
  • 2,411 posts
  • Edge's Year:2011
Posted 17 July 2017 - 06:47 AM
I am sticking with full synthetics as the blends IMO will not hold up to the high hours testing and the results will be incompatible to the synthetics.
#636 OFFLINE   macbwt
macbwt
    Ford Edge Fanatic
  • 2,411 posts
  • Edge's Year:2011
Posted 18 July 2017 - 08:07 AM
Red Line oil change with Purolator Boss filter.
This video is not a how to but a how Dad and daughter do things together.
#637 OFFLINE   macbwt
macbwt
    Ford Edge Fanatic
  • 2,411 posts
  • Edge's Year:2011
Posted 18 July 2017 - 08:13 AM
Hello everyone,  MAC T here and I am starting a new topic called double edged.  The situation is as follows:
I currently own and drive two Ford Edges. This topic will be used to follow two 2011 Ford Edge Limited as they both experience usage in opposition.  The Blue Metallic 2011 (MOMOSHA Car) driven mostly city driving and virtually no highway vs the Cinnamon Metallic 2011 (work car) which will be driven 95 percent of the time on interstates in long haul driving situations.
How will each one handle the different driving conditions?  What repairs will result in the greatly different usage?   Time will tell and it will be documented on this topic.
Note: The documentation of most repairs will be on video.
It has now been two years documenting the maintenance and repairs on both of the 2011 Edge's.  So far pretty good results and both are still reliable and run very well.
Had some repairs, but I would consider most to be under the consumable list.   Let's see what the future holds as the miles build up.
Also tagged with one or more of these keywords: 2011 Ford Edge, Limiited, comparison, High mileage, Low mileage, DIY
