Intermittent overheating 2011 Edge
On 8/19/2016 at 11:29 PM, enigma-2 said:
I had a problem (2009 MKX) of not cooling at idle (classic fan problem) and took it to my dealer. They checked the AC system and found it a little low on refrigerant (they told me that it was common to loose a small amount of coolant over the years). They evacuated the system to check for leaks and refilled. Then they changed the fan assy. Covered under the extended warranty but said the total bill would have been between $700-$800.
Others have reported problems with aftermarket fan assemblies (not working properly, noisier, vibrations, etc.) You might also consider pricing Motorcraft. Costs more, but your assured of not having any problems.
3 hours ago, OLA said:
Please my 2012 ford edge is behaving the same way. Please how can I resolve this.
The answer to your question is in this thread and in the post directly above yours !!!!
