Custom Search
Cooled Seats
  • Please log in to reply
164 replies to this topic
#1 OFFLINE   Wedgeamatic
Wedgeamatic
    New Edge Member
  • Edge Member
  • 52 posts
  • Region:Decline
  • Edge's Year:2015
Posted 10 September 2015 - 09:53 AM
Has anyone brought their Sport into the dealer for issues with the seat back not cooling?
I notice that in late August Ford issued a TSB on this issue for F150 owners.
#2 OFFLINE   Reloaded
Reloaded
    New Edge Member
  • Edge Member
  • 25 posts
  • Region:Decline
  • Edge's Year:2015
Posted 10 September 2015 - 10:17 AM
Ya know, I was starting to think it didn't have cooling in the back part of the seat. Checked the parts catalog, and it does indeed have 2 cooling fans per seat. The fan motor for both the F-150 and the Edge are the same. As mentioned, no TSB for the Edge, only the F-150 and it basically says to just cut away some of the material from the inside of the seat cover..
The TSB for the F-150 has a date of Sept. 8th.
Edited by Reloaded, 10 September 2015 - 10:21 AM.
  • Vadimus likes this
#3 OFFLINE   cds71
cds71
    Ford Edge Member
  • Edge Member
  • 354 posts
  • Region:Canada North
  • Edge's Year:2015
Posted 10 September 2015 - 11:53 AM
my seats seem to cool very well, there is an increase in seat temp on the back side of the seat....this heat does not seam to affect the cooling tho....some people have observed extreme heat issues while others have not(like myself).
#4 OFFLINE   akirby
akirby
    Ford Edge Legal Resident
  • Moderator
  • 11,102 posts
Posted 10 September 2015 - 12:38 PM
Same problem.  It appears Ford is still working on the permanent fix (for Edge at least).   The problem seems to be the exhaust hose comes off inside the seat just like the F150.
There are a couple of topics on it already posted.
#5 OFFLINE   27Sport
27Sport
    New Edge Member
  • Edge Member
  • 141 posts
  • Region:Decline
  • Edge's Year:2018
Posted 10 September 2015 - 02:50 PM
It also says to replace the blower motor with an updated part that has a redesigned air intake.
#6 OFFLINE   Wedgeamatic
Wedgeamatic
    New Edge Member
  • Edge Member
  • 52 posts
  • Region:Decline
  • Edge's Year:2015
Posted 10 September 2015 - 04:17 PM
Thanks. I've been doing a lot of traveling this summer and just haven't been in town long
enough to get it into the dealer for this issue. Let's see if we hear from anyone who has had their dealer look into this issue on the 2015 Edge.
#7 OFFLINE   akirby
akirby
  • Moderator
  • 11,102 posts
Posted 10 September 2015 - 04:32 PM
So that's why they didn't have a fix immediately.  Makes sense.
I wonder why they moved the fans from underneath the seat to inside the seat?
#8 OFFLINE   Reloaded
Reloaded
    New Edge Member
  • Edge Member
  • 25 posts
  • Region:Decline
  • Edge's Year:2015
Posted 10 September 2015 - 04:49 PM
The updated blower assy for the F-150 is only listed under the 2015 TSB. The part number is GU5Z-19N550-B. When you look it up in the catalog, both the Edge and F-150 motor lists as GU5Z-19N550-A. So I wonder if the updated part for the F-150 will work and if that's Ford will do. I'll likely bring my Sport in and see what the techs here think. Maybe I can see if one can contact the hotline and see if they have an interim fix or something.
Edited by Reloaded, 10 September 2015 - 05:06 PM.
#9 OFFLINE   akirby
akirby
  • Moderator
  • 11,102 posts
Posted 10 September 2015 - 04:57 PM
Most likely although there could be some minor difference due to the seats being different.
#10 OFFLINE   Reloaded
Reloaded
    New Edge Member
  • Edge Member
  • 25 posts
  • Region:Decline
  • Edge's Year:2015
Posted 10 September 2015 - 05:01 PM
Alright, I found a tech here to help me. He's going to contact the Ford tech hotline and see what they have to say about the problem; see if the TSB for the F-150 can be applied to this, or if they have another fix.
Ok, the tech sent the request in and I'll probably get a response tomorrow.
Edited by Reloaded, 10 September 2015 - 05:11 PM.
  • WWWPerfA_ZN0W likes this
#11 OFFLINE   FINFAN3DP
FINFAN3DP
    New Edge Member
  • Edge Member
  • 18 posts
  • Region:U.S. Northeast
  • Edge's Year:2015
Posted 10 September 2015 - 08:34 PM
I got my sport this past Sunday.... On the way home from the Dealership, my back was ice cold... Then I adjusted the lumbar, and it hasn't been cold since.
  • dtburton75 likes this
#12 OFFLINE   Rider404
Rider404
    New Edge Member
  • Edge Member
  • 7 posts
  • Region:Decline
  • Edge's Year:2015
Posted 11 September 2015 - 10:19 AM
Just dropped off my '15 Sport and talked to my service rep..."under investigation...I can show you how to do the hillbilly fix". :o(. Recommended calling Ford customer service. Let's all call!
#13 OFFLINE   Viper810
Viper810
    New Edge Member
  • Edge Member
  • 16 posts
  • Region:Decline
  • Edge's Year:2015
Posted 11 September 2015 - 11:42 AM
Just got my '15 Titanium back from the dealership.  I was having the same issues as above.  No cooling on seat back and was actually getting hot in the shoulder area.  They told me there are 2 different cooling fans, one for the seat bottom and on for the seat back.  The seat back fan has no exhaust ducting to let the heat escape.  So the fan motor heat is just sitting in the seat back causing it to warm up the seat.  So as of now my cooled seat back is actually a heated seat.  Not something I need here in Arizona in the summer.
They do agree that it is not working properly, but they have no fix for it at this time.  The service advisor recommended that I should contact Ford Customer Service.
Edited by Viper810, 11 September 2015 - 11:52 AM.
#14 OFFLINE   Reloaded
Reloaded
    New Edge Member
  • Edge Member
  • 25 posts
  • Region:Decline
  • Edge's Year:2015
Posted 11 September 2015 - 01:12 PM
Ok, the tech got a response. More of a non-response really though.
"At this time, TSB 15-0140 is not applicable to this vehicle and cannot be performed to resolve this concern.
Since the backrest of the driver's seat is not cooling properly, we recommend checking the passenger's seat backrest to determine if it is cooling. If the back rest for the passenger seat is cooling, but the driver's side is not cooling, it is suspected the blower motor for the driver's backrest is either clogged, the air ducting is loose, or the motor inlet or outlet is clogged. Check for restrictions and correct installation for the backrest blower motor as per workshop manual section 501-10A and re-evaluate the cooling concern."
#15 OFFLINE   Dz0n3
Dz0n3
    New Edge Member
  • Edge Member
  • 24 posts
  • Edge's Year:2015
Posted 11 September 2015 - 01:41 PM
Hmm .. i did not even know the back of the seats were supposed to cool too. Now that you guys mention it the back of my seats don't really cool only the bottom does. I have a Titanium. Should i take it to the deal or just wait it out? Does this mean that in the winter time the back of the seats should heat up as well ??
#16 OFFLINE   27Sport
27Sport
    New Edge Member
  • Edge Member
  • 141 posts
  • Region:Decline
  • Edge's Year:2018
Posted 11 September 2015 - 03:10 PM
Take it to the dealer, the more people that complain about the same issue the better chance it getting investigated and resolved.
#17 OFFLINE   Wedgeamatic
Wedgeamatic
    New Edge Member
  • Edge Member
  • 52 posts
  • Region:Decline
  • Edge's Year:2015
Posted 11 September 2015 - 10:42 PM
Agreed. I'll be making my call tomorrow. I would have never purchased suede seats in AZ if I knew the seats would not cool correctly as ADVERTISED.
This might be my last Ford. Love the vehicle but this is bull s@it.
#18 OFFLINE   akirby
akirby
  • Moderator
  • 11,102 posts
Posted 12 September 2015 - 06:52 AM
It's a simple engineering/manufacturing issue. It will be fixed.
#19 OFFLINE   boilerhawk14
boilerhawk14
    New Edge Member
  • Edge Member
  • 23 posts
  • Region:U.S. Great Lakes
  • Edge's Year:2015
Posted 14 September 2015 - 09:21 AM
I did an online chat with a Lincoln Concierge when we were checking out the new MKX and asked about the cooled seats.  After asking around and emailing me a response a day later, they said that only the bottom of the seat is cooled.  I'm not sure if the Edge is supposed to be the same as the MKX in this way, but I suspect it might be.
I now have a 2015 Titanium and was disappointed when I found out about the back not being cooled.  If someone gets their dealer to give them more information, please share!  Otherwise, I suspect that this is how the cooling is supposed to be.
I'm not sure who it is that has access to the repair manuals on this site, but I'm sure they could look in the seats section and find some detailed info about the cooling system in the seats.  That'll probably give the most detailed answer since if there's no hose hooked up to the seat back, then we have an answer!
  • Mage266 likes this
#20 OFFLINE   27Sport
27Sport
    New Edge Member
  • Edge Member
  • 141 posts
  • Region:Decline
  • Edge's Year:2018
Posted 14 September 2015 - 03:40 PM
Do not go by the people on the website chats, they have no idea besides the specs in front of them. Trust me, the seat backs are supposed to be cooled also. There are two fans in each seat, one in the bottom and one in the seat back. I've seen the dealer repair manual and it specifically states there are two fans. The repair illustrations also show two fans. It's a poor design with no way to get ambient cabin air to the seat back, and no way to exhaust it out. I have looked at my seats to see if there was a modification I could do to get cool air inside the seatback but there is no easy way to get to the fans. The whole seatback is basically sealed up. The F150 is easilly accessible with a zipper while the Edge is sewn up and uses metal rings to hold it down.
