Custom Search
Sign In  Log in with Facebook
Create Account
Click here to signup now
Guest Message by DevFuse
Check out the Ford Edge ST Forum Here
Kick option on tailgate
  • Please log in to reply
7 replies to this topic
#1 OFFLINE   Laurie
Laurie
    New Edge Member
  • Edge Member
  • 3 posts
  • Region:U.S. Pacific Coast
  • Edge's Year:2015
Posted 18 October 2015 - 11:15 PM
I have only owned my 2015 edge since Labor Day and three separate times, while bent into the trunk, the automatic tailgate started closing. Anybody else experiencing that? It was quite scary and alarming, and good thing, my key was nearby and I was able to press the button to stop it. If it was an infant or an expensive golf club, I'm afraid it might have been crushed.
#2 OFFLINE   omar302
omar302
    Ford Edge Addict
  • Edge Platinum Member
  • 1,848 posts
  • Region:Middle East
  • Edge's Year:2016
Posted 18 October 2015 - 11:38 PM
I'd guess you might have been very close to the back of your Edge that your foot was actually within the kick sensor range. If the feature is not suited for you, maybe it can disabled in left screen menu.
Also note that the power tailgate has an Obstacle Detection mechanism for safety so rest assured that would not have a crushing force if it closes on something, and I don't think an infant can be left positioned in the path of the lift gate.
Obstacle Detection
When Closing
The system stops when it detects an obstacle. A tone sounds and the system reverses to open. Once you remove the obstacle, you can power close the liftgate.
Note: Entering your vehicle while the liftgate is closing can cause your vehicle to bounce and activate obstacle detection. To prevent this, let the power liftgate close completely before you enter your vehicle. Before driving off, check the instrument cluster for a liftgate or door ajar message or warning indicator. Failure to do this could result in unintentionally leaving the liftgate open while driving.
When Opening
The system stops when it detects an obstacle and a tone sounds. Once you remove the obstacle, you can continue to operate the liftgate.
#3 OFFLINE   ruyehara47
ruyehara47
    New Edge Member
  • Facebook Member
  • 18 posts
  • Region:Decline
  • Edge's Year:2016
Posted 19 October 2015 - 02:59 AM
I saw a video review on YouTube that talked about the lift gate closing on the tester a couple times.
Edit: I found the video. He talks about it right at the 8 minute mark.
Edited by Ryan Uyehara, 19 October 2015 - 03:04 AM.
  • WWWPerfA_ZN0W likes this
#4 OFFLINE   omar302
omar302
    Ford Edge Addict
  • 1,848 posts
  • Edge's Year:2016
Posted 19 October 2015 - 05:48 AM
The tester clearly wiggled his foot below the bumper.
#5 OFFLINE   Waldo
Waldo
    Ford Edge Enthusiast
  • Edge Member
  • 1,014 posts
Posted 19 October 2015 - 10:31 AM
If you haven't tested out the obstacle detection feature, make sure you do.  Then you won't be so scared.
#6 OFFLINE   Anna1045
Anna1045
    New Edge Member
  • Edge Member
  • 2 posts
  • Region:Decline
  • Edge's Year:2015
Posted 07 December 2015 - 01:12 PM
I had this happen to me Friday. I was loading groceries and stepped too close to the rear and the lift gate came down on my head HARD and it never detected me - I heard the chimes but never registered what they were. I have a knot the size of a quarter on the top side of my head. Two women witnessed it in a grocery parking lot and were shocked that I was not knocked unconscious.  I waited a few minutes to stabilize and drove straight to dealer. They could not turn off the auto lift gate. Even disabling it on the menu did not keep it from being triggered by your foot and coming up and down.  They also tested the detection feature and could not get it to auto reverse ever. The service department is researching and I am too..... I read that that Ford Escape obstacle detection works but as of this writing, my Ford Edge auto lift gate is a lethal weapon.
#7 OFFLINE   omar302
omar302
    Ford Edge Addict
  • 1,848 posts
  • Edge's Year:2016
Posted 08 December 2015 - 12:06 AM
Glad your ok. Yes it was bad, but I wouldn't call "Lethal". Anyway, if you don't need the "kick" option, I'd guess the easiest solution is to disconnect the sensors under the car.
#8 OFFLINE   WWWPerfA_ZN0W
WWWPerfA_ZN0W
    Ford Edge Legal Resident
  • 8,701 posts
  • Region:U.S. Northeast
  • Edge's Year:Decline
Posted 08 December 2015 - 06:07 AM
Wow, that's def a bad experience, Anna, hope you are 100% ASAP!  Can't imagine why the obstacle detection didn't work on the Edge, may need a Ford Engineer to look into this.  Consider having the issue escalated at the dealership, or, if they don't want to, you can PM FordService on here.  This is not a small issue, and should be properly addressed.
  • PrinzII likes this
