Custom Search
Sign In  Log in with Facebook
Create Account
Click here to signup now
Guest Message by DevFuse
Check out the Ford Edge ST Forum Here
Outside air temp sensor not working
  • Please log in to reply
28 replies to this topic
#1 OFFLINE   Jonathan Lynch
Jonathan Lynch
    New Edge Member
  • Facebook Member
  • 21 posts
  • Region:U.S. Pacific Coast
  • Edge's Year:2016
Posted 11 February 2016 - 06:32 PM
Hi all.  Got my 2016 Edge Sport last weekend.  Noticing that the outside air temp never updates.  After the car has been off for a number of hours, it will take an initial reading, but that never changes afterwards, until I turn off the car again for a number of hours.  Making the climate auto control pretty useless.  Taking to dealership tomorrow to have LoJack installed and will ask them to check it out. Anyone else noticing this? Any fixes?
#2 OFFLINE   Jonathan Lynch
Jonathan Lynch
    New Edge Member
  • Facebook Member
  • 21 posts
  • Edge's Year:2016
Posted 13 February 2016 - 07:19 AM
So went to the dealer today. Temp sensor has been working, kind of. Fiddled with it a bit with my finger through the grill (it's under the right headlight, towards bottom, and behind the grille. Seems the issue is that it works differently than my 2012 Edge. That sensor updated continuously. My 2016 sensor seems to need a little sustained speed (around 40 mph for a minute or so). Unfortunately for me, I live in Los Angeles traffic hell, and rarely get on the freeway. Have an appt to have it checked, but not until first week of March. Anyone else getting this issue? Are my deductions/observations about speed correct? Anyone? Bueller?
#3 OFFLINE   WWWPerfA_ZN0W
WWWPerfA_ZN0W
    Ford Edge Legal Resident
  • Edge Platinum Member
  • 8,707 posts
  • Region:U.S. Northeast
  • Edge's Year:Decline
Posted 13 February 2016 - 09:42 AM
Hopefully just a loose wire?  Other than a bad unit, that's the most likely prospect, I think.  Don't know if there's any interplay with active grille shutters, assuming your Edge has them.
#4 OFFLINE   djrjr
djrjr
    New Edge Member
  • Edge Member
  • 27 posts
  • Edge's Year:2015
Posted 13 February 2016 - 10:58 AM
My cousin's Cruze (I know, I know not at all a Ford Edge) does the same thing in regards to being slow to update the outside air temperature.  The solution was in finding the logic behind when it updates:
If the vehicle is driven at:
25-40♦km/h (15-25♦mph), the display will update after 5 minutes.
41-60♦km/h (26-37♦mph), the display will update after 2 min 30 sec.
61-100♦km/h (38-62♦mph), the display will update after 1 minute.
Once the first temperature update begins, the outside temperature display is refreshed every 2 seconds.
I wonder if the Edge has similar logic built in.
#5 OFFLINE   Jonathan Lynch
Jonathan Lynch
    New Edge Member
  • Facebook Member
  • 21 posts
  • Edge's Year:2016
Posted 17 February 2016 - 04:45 AM
Thanks djrjr...
My problem is now that I am in Los Angeles traffic and can barely drive 25-40 for 5 minutes due to all my the traffic, lights, and stop signs. Makes my normal daily work commute impossible to get temp updates. Boo.
#6 OFFLINE   Jonathan Lynch
Jonathan Lynch
    New Edge Member
  • Facebook Member
  • 21 posts
  • Edge's Year:2016
Posted 23 February 2016 - 10:00 PM
Ok, I officially hate the outside temp gauge. Drove around today for hours in 85+ temps and outside air gauge never moved from 70 degrees. Seems I have to get on the freeway to have it update, but I never need to drive on freeway, mainly just around town. What's the point of this thing?
#7 OFFLINE   Jonathan Lynch
Jonathan Lynch
    New Edge Member
  • Facebook Member
  • 21 posts
  • Edge's Year:2016
Posted 24 February 2016 - 07:39 AM
Ok, found this on another site. It is from the 2013-2014 Ford Escape Repair Manual, but the Ambient Air Sensor is the same part # as the 2016 Edge. Thus, this info probably applies to me. LA traffic is to blame for my problem....
Outside Air Temperature Display
The Ambient Air Temperature (AAT) sensor provides the Ambient Air Temperature (AAT) data used for the outside air temperature display in the IPC. The Ambient Air Temperature (AAT) sensor is hardwired to the PCM through separate input and return circuits. The PCM provides a reference voltage to the Ambient Air Temperature (AAT) sensor and monitors the change in voltage resulting from changes in resistance as determined by outside air temperature. The PCM filters the Ambient Air Temperature (AAT) input and sends the BCM the air ambient temperature filtered message over the HS-CAN. The BCM sends the air ambient temperature filtered message to the IPC over the MS-CAN.
Due to the location of the Ambient Air Temperature (AAT) sensor in the front grill area, it is greatly influenced by heat generated from the engine compartment at low vehicle speeds and at engine idle. For this reason the outside air temperature value displayed in the IPC does not update in the upward (hotter) direction under 33 km/h (20 mph). This update strategy is used because the PCM is unable to determine whether the increase in temperature is truly from an ambient temperature rise or by heat generated from the engine compartment.
The outside air temperature display in the IPC updates in the upward (hotter) direction under either of the following situations:
- if the vehicle is driven over 33 km/h (20 mph) continuously without the vehicle speed dropping below 33 km/h (20 mph) for approximately 90 seconds.
- if the vehicle is allowed to sit with the engine off for approximately 6 hours (the outside air temperature display in the IPC immediately updates to reflect the current ambient conditions since the engine has cooled sufficiently and no longer has an effect on the outside air temperature sensor reading).
NOTE: If the vehicle speed drops below 33 km/h (20 mph) before the outside air temperature display in the IPC begins to update, the PCM logic resets and the time starts over.
Because this filtering strategy exists, it may be necessary to drive the vehicle continuously above 33 km/h (20 mph) for approximately 90 seconds when observing the outside air temperature display operation. After the vehicle has been driven above 33 km/h (20 mph) for 90 seconds, the outside air temperature display in the IPC starts to rise (filter upward), increasing toward the actual outside air temperature. Depending on the difference between what the outside air temperature is displaying in the IPC and the actual outside temperature, it can take several minutes for the outside air temperature display in the IPC to reach the outside temp.
The outside air temperature display in the IPC does not filter in the downward (colder) direction and always displays the coldest temperature detected by the sensor even when the vehicle is stationary. When the outside Ambient Air Temperature (AAT) is lower than the temperature displayed in the IPC, the IPC immediately updates the displayed temperature downward to reflect the colder ambient air temperature, even at idle.
  • factor99, WWWPerfA_ZN0W and omar302 like this
#8 OFFLINE   enigma-2
enigma-2
    Ford Edge Fanatic
  • Edge Member
  • 2,882 posts
  • Region:U.S. Great Lakes
  • Edge's Year:2009
Posted 24 February 2016 - 08:19 PM
I wonder if one were to build a shield over the back of the sensor (blocking the heat of the engine) would partially correct the problem?
#9 OFFLINE   omar302
omar302
    Ford Edge Addict
  • 1,849 posts
  • Region:Middle East
  • Edge's Year:2016
Posted 25 February 2016 - 11:37 PM
I wouldn't mess with that area as it is already optimised for proper air flow into the condenser/radiator and aerodynamics. Also some models have active grille shutters in the same area.
I remember for the 2011+ MKX already, there are two different parts for the support behind the grille (the black mesh piece with holes in it) for tow & non-tow models, again confirming the airflow dynamics.
Edit: the parts can be seen here.
Edited by omar302, 25 February 2016 - 11:40 PM.
#10 OFFLINE   frmichaud
frmichaud
    New Edge Member
  • Edge Member
  • 15 posts
  • Region:Canada Quebec
  • Edge's Year:2016
Posted 08 November 2016 - 04:45 PM
I have a 2016 Ford Edge Titanium and the outside temperature don't work, it change some time but never indicated the proper value, I left 2 time my Edge at my Ford Dealer , each time they changed the sensor
The problem remain the same, only the value display is different
Does some body has the same problem and how was it fixed?
Thanks
Francois
Edited by frmichaud, 08 November 2016 - 04:51 PM.
#11 OFFLINE   frmichaud
frmichaud
    New Edge Member
  • Edge Member
  • 15 posts
  • Edge's Year:2016
Posted 24 November 2016 - 09:07 AM
Ithink my technician found the problem of the wrond display of temperature
They found water and oxydation in Connector C140 located in the Left Front Fender masqued by the liner, it is necessary tu peplace the 2 pigtale  male and female and replace them
I have the 2 parts in order and they must be replaced nex week , I will let you know the result
Francois
  • WWWPerfA_ZN0W likes this
#12 OFFLINE   WWWPerfA_ZN0W
WWWPerfA_ZN0W
  • 8,707 posts
Posted 24 November 2016 - 09:09 PM
Good luck, would be a relatively simple fix. Make them put a dab of dielectric grease in there.
#13 OFFLINE   frmichaud
frmichaud
    New Edge Member
  • Edge Member
  • 15 posts
  • Edge's Year:2016
Posted 25 November 2016 - 11:20 AM
It is long , it is necessary to remove front left wheel and the liner to have acces to the connector,
I ordered the parts but will have them in a week
Will let you know if it works
Francois
#14 OFFLINE   frmichaud
frmichaud
    New Edge Member
  • Edge Member
  • 15 posts
  • Edge's Year:2016
Posted 25 November 2016 - 12:43 PM
In Hamradio we use a rubber tape very sticky to isolate our connectors outside, when you wat to remove it is xtill soft and you peel it, I will put a piece on the connector so it will be totaly waterproof
https://www.amazon.c...s/dp/B00K4PZ9NO
#15 OFFLINE   Mirage52
Mirage52
    New Edge Member
  • Edge Member
  • 131 posts
  • Edge's Year:2017
Posted 10 January 2018 - 08:41 AM
The issue with my temperature sensor is that it reads way higher when I start my car in the morning after sitting overnight. So when I use auto start in freezing temperatures, it'll read in the 60's or 70's meaning there is no heated seats or defrost coming on when it warms up.I did drive in frigid temps this past weekend with some snow and lots of road salt so I am wondering if this is having an effect on it.
Looks like I'll be taking it to the dealer. Not even 5K miles on it yet...sheesh.
Edited by Mirage52, 10 January 2018 - 08:47 AM.
#16 OFFLINE   akirby
akirby
  • Moderator
  • 10,568 posts
Posted 10 January 2018 - 09:12 AM
That's definitely not right.   Worst case it should retain the temp from the previous evening.  Probably an easy fix.
#17 OFFLINE   Mirage52
Mirage52
    New Edge Member
  • Edge Member
  • 131 posts
  • Edge's Year:2017
Posted 10 January 2018 - 02:19 PM
Just started the car. Said temp was 113 degrees. It's in the forties.
Just called the dealer to schedule a service time. Apparently they need to diagnose the problem before I can have a loner. They said it'll take a day to diagnose the issue. I said just turn the damn car on and look at the temperature!!!
So they want me to drop the car off 10 miles away, figure out a way to work and back 18 miles away, and then bring the car back when they can work on it and I can get a loaner.
WTF, man. WTF.
#18 OFFLINE   akirby
akirby
  • Moderator
  • 10,568 posts
Posted 10 January 2018 - 03:06 PM
Ridiculous.   The diagnostic would tell them what to replace.  They can see it's broken in 2 seconds.  Can you try another dealer?
#19 OFFLINE   Mirage52
Mirage52
    New Edge Member
  • Edge Member
  • 131 posts
  • Edge's Year:2017
Posted 10 January 2018 - 03:40 PM
I know, right? A joke.
I'm taking it in first thing Monday morning and asking them to diagnose the problem while I wait. I'll have about an hour. Then they can keep it and fix it and I will be on my way with a loaner, or I will just take the car to work and look elsewhere for a fix. There's another dealer closer to where I work, so that'll be my fallback option.
Just hoping that this is dealer speak...I've bought two cars at the dealer in the last 5 years.
Edited by Mirage52, 10 January 2018 - 03:41 PM.
#20 OFFLINE   jmr061
jmr061
    Ford Edge Member
  • Edge Member
  • 356 posts
  • Edge's Year:2016
Posted 10 January 2018 - 03:54 PM
@Mirage52...In the mean time disconnect the battery (negative) terminal for a few minutes to see if that clears the issue.  Did I read that right...you have a 13 with 5000 miles on it?
