Dealer left driveshaft bolts untightened. Is this correct?
Are these bolts left untightened correct? I have a lot of vibration.
My 2007 Ford Edge was at the dealer today for a fuel tank replacement due to a recall. To replace it they have to unbolt the rear driveshaft. The car vibrated a lot (much more than usual) on the ride home. Is this normal? The bolts can be spun by finger.
Is that shot from where the driveshaft connects to the RDU? Do you know if it was "oily" before? Hopefully it's just the techs being messy, but it could be the rear pinion seal is going also.
That is the connection at the rear of the driveshaft below the fuel tank, is that the RDU or PTU? I don't remember that area being oily but I'm not 100% confident on that. Is there a way to check?
