Cooling issues
Andredqg5
Does your radiator fans come on when switch on the ac? May not be getting sufficient airflow through the condenser if the fans aren't working at idle but get airflow when moving (esp above 30 mph).
Other thoughts are low refrigerant. Pressure builds with engine speed. (Do you get cold air at idle if you goose the engine, say 3000 rpm)?
Getting any codes? If you don't have a code reader, usually can get you codes read at Auto Zone or simular place.
