OEM Trailer Lighting Not Working
I have a 2016 Edge Titanium 2.0 purchased only a week ago. I hooked up my jetski trailer and have no lights at all, then tried a 4 pin tester and still got nothing from the plug. The only info I can find about fuses is 1 fuse under the power distribution box labeled "Trailer Lighting Module". This fuse is confirmed good with a multimeter.... Is there any other fuses for the lighting itself?
Edited by gjas24
So after a little digging in fords documentation I figured out the problem.... The connector from the exterior wiring harness to the interior wiring harness was not connected. (I took a picture to help other people out but it came out really dark for some reason.) The two connectors for the trailer plug pigtail are located under the passenger side rear bumper. There is a plastic cover right next to the exhaust tip, remove the two screws into the bumper and you can pull it back to see the wires.
It was just hanging there disconnected.
