Custom Search
Sign In  Log in with Facebook
Create Account
Click here to signup now
Guest Message by DevFuse
The official Ford authorized Ford Edge Registry is now live. More here!
Add remote start 2015 Edge
  • Please log in to reply
64 replies to this topic
#61 OFFLINE   nittanydoug
nittanydoug
    New Edge Member
  • Edge Member
  • 34 posts
  • Region:U.S. Great Lakes
  • Edge's Year:2014
Posted 01 June 2017 - 07:58 PM
I have to keep an eye on these threads. I take possession tomorrow of my 2014 Edge SEL with power lift gate. I doesn't have a remote start on the key. Plus they only had one key, so I ordered 2 blank keys with the 5 button remote. I'll have to start seeing if I have a hood button. There was one identical on the dealers lot minus nav and it had remote start. Window stickers were identical down to the color and package 205a. They lost the other key and this one may be a replacement as it is. I guess I'll still have to have the dealer program the keys but I need a spare key. Any tips on which direction to go or what I should look for to see what I have already?
#62 OFFLINE   WWWPerfA_ZN0W
WWWPerfA_ZN0W
    Ford Edge Legal Resident
  • Edge Platinum Member
  • 8,217 posts
  • Region:U.S. Northeast
  • Edge's Year:Decline
Posted 02 June 2017 - 03:51 AM
Take a look at candurin's thread here, since you have a 2011-14 Edge
http://www.fordedgef...-detailed-2011/
#63 OFFLINE   nittanydoug
nittanydoug
    New Edge Member
  • Edge Member
  • 34 posts
  • Edge's Year:2014
Posted 02 June 2017 - 09:59 AM
Thanks.  There were so many I couldn't remember which one had the most concise info.
  • WWWPerfA_ZN0W likes this
#64 OFFLINE   Exploder82
Exploder82
    New Edge Member
  • Edge Member
  • 2 posts
  • Edge's Year:2016
Posted 16 June 2017 - 10:37 AM
Definitely can enable remote start with Forscan, i've done it with my 2015 SEL.  Remote start is now enabled, and options can be controlled via the IPC.  All I need to do is find a key, and see if it works without adding the antenna :)
how did you enable it? Is the option in forscan to turn it on or off? If not, what settings need changed?
#65 OFFLINE   Gortty-Pilot
Gortty-Pilot
    New Edge Member
  • Edge Member
  • 43 posts
  • Region:Decline
  • Edge's Year:2011
Posted 04 July 2017 - 12:23 AM
With Forscan in the following order:
In the BCM change (leave the Xs or ...s alone)
726-19-01: 0148 XXXX XXXX -Enabled
0047 XXXX XXXX -Disabled
In the IPC Module change to either
720-01-03: C8F3 XXXX XXXX - base model
Or F823 .... .... climate seats only
Or FC27 .... .... climate seat & heated
steering wheel
This is per an Explorer 2011-2015 spreadsheet that I've used and apoears to be confirmed by Exploder82
