Aftermarket headlamp help please
So I bought aftermarket headlamp assemblies for my 2010 ford edge, they look great, only problem is they are not bright enough for where I live. I have the assemblies from carid.com, originalfactory assemblies call for two bulbs, a hi and a low (H11 and 9005) these aftermarket ones go to a single H11 bulb and when you activate high beams a apperture opens to widen the beam.... Problem is its still a low beam. Im wondering if anybody has used LEDs or HIDs with this aftermarket assemblies or if anybody knows how to get a 9005 bulb onto a H11 retainer ring to install in the housings? post-38478-0-68738400-1484264677_thumb.jpgpost-38478-0-77401500-1484264687_thumb.jpg
You could just upgrade the lamps in the stock housing.
I just changed my H11 low beams to H9s. Technically it's not legal since it's above 55W (65W) but they are not blinding in any way.
I also changed the high beams from 9007s to 9011 HIRs. The 9011 HIRs have much better output, but a short life span. Not a big deal since I rarly run with the brights on.
Both changes took a slight mod to the lamp base tabs, and the 9011 HIRs needed a rib trimmed out of the electric plug in area. Took about 2-3 min per bulb.
65 watt bulbs are street legal. Take for example Sylvania Silverstar's. They're 65 watt. They sell millions of them.
You might be right. I was walking around the auto department at Meijers Saturday and was casually looking at Silverstar's packaging. Everything I looked at was 65 watt, but wasn't really looking to see if they were low or high beam. I don't recall reading where theres a wattage limit in the FMVSS. Years ago, here in Indiana there used to be a legal limit of 100,000 cp total at the front of a car. Was talking to a state patrol officer as to how they enforce to law, said he just looks for excessive glare. If it hurts his eyes, they get stopped. He requires them to get lights checked by a professional mechanic.
