INCORRECT MEMORY SEAT OPERATION AND/OR EASY ENTRY/EXIT SEAT OPERATION – BUILT ON OR BEFORE 3/11/2016
Publication Date: June 16, 2016
2016 Explorer, 2016 MKX
ISSUE:
Some 2016 Explorer and MKX vehicles built on or before 3/11/2016 may exhibit a memory seat that does not return to the programmed position when pressing the memory seat switch or programmed intelligent access (IA) key; and/or easy entry/exit function that does not return to the previous seat position.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
1. Check the vehicle build date. Was the vehicle built on or before 3/11/2016?
a. Yes – proceed to Step 2.
b. No – this article does not apply. Refer to Workshop Manual (WSM), Section 501-10 for normal diagnostics.
2. Reprogram the driver seat module (DSM) to the latest calibration using the Integrated Diagnostic System (IDS) version 100.05 or higher. Make sure you are connected to the internet when entering module programming to obtain the latest calibration. Calibration files may also be obtained at www.motorcraftservice.com.
3. Use IDS to perform a DSM reset. Select the following:
a. Body
b. Service functions
c. DSM reset and press the tick mark.
4. Use the IDS to update the as-built data in the DSM. Select the following:
a. Module programming and press the tick mark.
b. As-built
c. DSM and press the tick mark.
d. You may see a screen requesting VIN verification. Press the tick mark.
e. Verify the VIN is correct by selecting yes.
f. Select no if the IDS asks were you sent here for part numbers or from another procedure.
g. Automatic and press the tick mark.
h. Follow the IDS prompts to complete the procedure.
After completing the procedure, advise the customer their memory seat locations and IA keys with programmed seat locations will need to be reset.
OPERATION DESCRIPTION TIME
160090A 2016 Explorer And MKX: Reprogram And Reset The DSM Following The Service Procedure (Do Not Use With Any Other Labor Operations) 0.4 Hr.
WARRANTY STATUS
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage.
Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
DEALER CODING
BASIC PART NO. CONDITION CODE
14C708 04
________________________________________
Module Reprogramming & Initialization
Software necessary to program electronic modules to the latest calibration level, perform module initialization (PATS), and set Programmable Parameters on Ford, Lincoln and Mercury vehicles.
Ford Module Programming (FMP) is a software application that allows subscribers to program electronic modules on Ford, Lincoln and Mercury vehicles. It can be used for:
• Reprogramming emission-related (OBDII) modules on some vehicles manufactured in 1995 and all vehicles manufactured from 1996 to the present
• Reprogramming or reconfiguring non-emission-related modules on many vehicles (UBP and MS-CAN not supported)
In addition, module initialization (PATS) functions such as Keycode Erase/Reprogram and PCM Parameter Reset can be done using this application.
J2534 Device using Ford Module Programming (FMP) can Reprogram and Configure most Modules.
Latest Calibration Information
Module Build Data (As-Built)
Use VIN to obtain As-Built data
