Engine CEL/MIL code P0019
Alexxbaconator
How many miles on your 2008? It could be sensors or wiring, but might indeed be a timing chain issue. Are you seeing symptoms or just a code, and under what conditions?
Actually a wide variety of reasons for this possibly.
Causes Causes may include:
  1. Timing chain stretched, or timing belt skipped a tooth due to wear
  2. Misalignment of timing belt/chain
  3. Tone ring on crankshaft slipped/broken
  4. Tone ring on camshaft slipped/broken
  5. Bad crank sensor Bad cam sensor
  6. Damaged wiring to crank/cam sensor
  7. Timing belt/chain tensioner damaged
  8. An improperly torqued crankshaft balancer
  9. A mis-built or mis-timed engine
  10. A loose or missing crankshaft balancer bolt
  11. The CMP actuator solenoid stuck open
  12. The CMP actuator stuck in a position other than 0 degrees
Read more at: https://www.obd-codes.com/p0019
Copyright OBD-Codes.com
Also, AFAIK, there is 1 camshaft position sensor (CPS) per bank, 1 crankshaft position sensor (CKS) for the entire engine, and 1 VCT solenoid per bank. VCT solenoid failure, timing chain stretch, and the occasional CKS failure are known to happen. If the timing chain needs R&R, change the water pump also as it is driven by the timing chain.
You can try unplugging the VCT solenoid on bank 1 with the neg batt cable disconnected for 15-30 minutes, then plugging it back in. Let the vehicle relearn. Same with the CPS on Bank 1. The VCT solenoid is on the top of the left side of the valve cover, the CPS to the right of the valve cover.
Only symptoms I can see,
Takes like 2 seconds longer to start when cold,
And it shakes a bit more on idle.
Nothing serious but the check engine light is on.
I want to check the cam sensors, I've seen online that I can checking the resistance on the sensor.
Do you know the resistance on the sensors?
