Reset ECU/PCM after new tune
EdgeS16
Which tuner? You can do the KAM reset if you have an SCT device.
I think the livernois can't do it, is there a way to do the KAM reset after loading the LMS tune, I know if you disconnect the battery maybe you can do it but sure what's the correct steps.
This just seems like a rough way to do it. You are basically killing the Capacitors quickly to clear the KAM. You could use FORSCAN to do it with out disconnecting ANY battery. Honestly, a slow draw by disconnecting the battery and letting it sit, would be a better method than described in this video. Clearing it via FORSCAN would by far be the best method.
