Need Help Troubleshooting 2011 Edge. Cooling Fans Not Coming On. Success! Thanks!
goslats
Daughter is in town and complaining about engine overheating while car not moving. I checked the #39 fuse and it is fine. The fuse has 13v coming in. A/C full blast and neither fan comes on. I don't see a relay in the power distribution box under the hood. Suggestions? Thanks
Edited by goslats
It's either the fan or the fan controller. You get both as a replacement kit. Fairly simple DIY job. Dormans are cheap and worked for me but others have had issues. Other aftermarket brands are worse. Motorcraft is the best option.
www.fordedgeforum.com/topic/12731-radiator-fan-assembly-replacement-procedure
I am getting 13v into the controller and 13v out. 2 fans and neither is coming on. Seems one fan would come on and not both at same time. Could it be something besides the fans and controller? If I need to I'll get the kit too akirby, It's about $210 here and the controller itself is nearly that much.
  • 7 years later...
