Custom Search
Sign In  Log in with Facebook
Create Account
Click here to signup now
Guest Message by DevFuse
Check out the Ford Edge ST Forum Here
* * * * * 2 votes
H&R SPORT SPRINGS ON G2 EDGE SPORT
  • Please log in to reply
149 replies to this topic
#141 OFFLINE   Mikula
Mikula
    Ford Edge Member
  • Edge Member
  • 469 posts
  • Region:Decline
  • Edge's Year:2016
Posted 25 November 2017 - 02:28 PM
anyone have torque specs or where to find them? the only one i'm actually concerned about is the top nut on the front strut. those springs are so much shorter than factory
#142 OFFLINE   Mikula
Mikula
    Ford Edge Member
  • Edge Member
  • 469 posts
  • Region:Decline
  • Edge's Year:2016
Posted 25 November 2017 - 03:12 PM
answered my own question. dealer said 26 ft lbs
#143 OFFLINE   Nick Halstead
Nick Halstead
    Ford Edge Enthusiast
  • Facebook Member
  • 1,106 posts
  • Region:U.S. Pacific Coast
  • Edge's Year:2015
Posted 25 November 2017 - 03:44 PM
Nick,
As noted at the very beginning of page one "You don't need to remove the wipers. Just lift up the plastic covering/shroud after removing the little metal clips, then you can access the rear bolt hiding there".
But the part that I'm amazed at is how did you remove the strut without performing page 4???
Everyone realizes that you may be the Ford Edge Sport GOD and you find no value in our efforts however, we've been receiving multitudes of kudos and appreciation from others who do.
At every opportunity we even make a special effort to give you, Xtra & Root credit i.e. "however lets not forget who motivated us".
BTW, you have consistently been the only negative critique to our efforts to help others, oh well I guess there has to be one in every group.
Oh, we failed to mention Happy Holidays Brother-In-Arms... :salute:  :salute:  :salute:
3 pages, I thought the text was it's own page.
Must be personal to you, cause I have no clue what your talking about btw...
Edited by Nick Halstead, 25 November 2017 - 03:44 PM.
  • gjb89 likes this
#144 OFFLINE   Mikula
Mikula
    Ford Edge Member
  • Edge Member
  • 469 posts
  • Region:Decline
  • Edge's Year:2016
Posted 25 November 2017 - 05:06 PM
Ok I finished the fronts. my passenger front side sits 3/4" higher than the driver side (ground to fender). not sure if they will settle with time, but its quite noticeable as of right now.  anyway, i didn't take off the wipers, but for everything else, here are the tools required:
Flathead Screwdriver (for pushpins if you are removing the plastic wiper cowl trim)
8mm (for the screws holding the lower plastic tray)
13/16" for lugnuts
10mm for the brake line bracket
6mm hex for center of sway bar end link
18mm for sway bar end link nut
24mm for strut to spindle nuts***
***Note that these bolts must be removed by taking the nut off, not by spinning the bolt head side. they have ridges/splines that keep them in place on the spindle.
hammer (for smacking out the spindle mount bolts)
13mm for strut tower bolts
21mm for strut nut for top hat removal
simple!
Edited by Mikula, 25 November 2017 - 07:33 PM.
#145 OFFLINE   One Slow 5.0
One Slow 5.0
    New Edge Member
  • Edge Member
  • 20 posts
  • Region:Decline
  • Edge's Year:2015
Posted 29 November 2017 - 07:51 PM
Does anyone have the torque specs for the rear subframe abd both front and rear shock bolts?
#146 OFFLINE   Mikula
Mikula
    Ford Edge Member
  • Edge Member
  • 469 posts
  • Region:Decline
  • Edge's Year:2016
Posted 29 November 2017 - 08:04 PM
Your best bet is to just call a dealer. they have the info you need. have your vin # handy. you might even have better results stopping by in person, they tend to take people more seriously.
the rear subframe i used the impact gun and ran it down same as i would my lug nuts. not that its the technical way to do it.. but that's what i did.
#147 OFFLINE   blownZ71
blownZ71
    New Edge Member
  • Edge Member
  • 4 posts
  • Region:U.S. Southern Atlantic
  • Edge's Year:2015
Posted 08 December 2017 - 11:39 AM
The H&R springs from Tire Rack  #28759-2, it states for AWD models. Will these also work on the 2015 FWD Sports?
#148 OFFLINE   roots57
roots57
    Ford Edge Member
  • Edge Member
  • 365 posts
  • Edge's Year:2016
Posted 10 December 2017 - 06:51 PM
I believe that they are the same for the fwd sport, nick h. has them on his fwd 2015 sport
  • WWWPerfA_ZN0W likes this
#149 OFFLINE   snmjim
snmjim
    New Edge Member
  • Edge Member
  • 199 posts
  • Region:U.S. Northeast
  • Edge's Year:2016
Posted 10 December 2017 - 08:48 PM
We installed them on J.Bishop's 2015 Sport FWD without an issue 2 date.
#150 OFFLINE   Nick Halstead
Nick Halstead
  • Facebook Member
  • 1,106 posts
  • Edge's Year:2015
Posted 10 December 2017 - 11:52 PM
Correct, way way way way back in March, after almost 2 years of monthly emails I got them to come to light!!!
17457702_10210661083856660_6410406202770
  • WWWPerfA_ZN0W and Xtra like this
