Custom Search
Sign In  Log in with Facebook
Create Account
Click here to signup now
Guest Message by DevFuse
Check out the Ford Edge ST Forum Here
Fluttering Noise from Undercarriage and Dashboad Rattle
flutter flutter noise underbody noise dashboard rattle dash rattle dash noise
  • Please log in to reply
15 replies to this topic
#1 OFFLINE   CCMAYES72
CCMAYES72
    New Edge Member
  • Edge Member
  • 3 posts
  • Region:Decline
  • Edge's Year:2016
Posted 17 June 2017 - 07:02 PM
2016 Ford Edge SEL
I purchased a new 2016 SEL from Ford and immediately noticed a "fluttering" noise or what sounded like a strap flopping around under the passenger side of the car.  I crawled under thinking that maybe something was left loose, or a strap was flopping around in the wind under the body.  I could not find anything obvious.  I did see a long hard board with a felt like finish that covers the under-body with unique and noisy center connectors.  I took the car in to a Lincoln dealership and they had already dealt with the same issue on a different but same year Edge.  They told me it was the rattle in the center connector of under-body "felt" panels.  They corrected the issue by installing some sort of buffer material in the fasteners.  The noise is now gone.  It was loud and annoying at times, in particular when heavy cross wind was coming from the passenger side of the vehicle.  I chose to start this message because I know this concern is not unique to my vehicle.  I travel for a living and often have Ford Edge rentals, and about 1 out 2 have the same noise.  It must be a known issue to Ford, however the Lincoln service adviser said there is no TSB for this issue.  I also had the Lincoln warranty service address what sounded like cheap plastic to plastic noises coming from the dash while traveling over rough road.  They isolated the poorly designed fasteners and buffered them as well.  The dash noise is now much improved.  I am disappointed in Ford for first not building this vehicle better, this is not a first generation model and these types of issues should be long since engineered out of the platform in my opinion.  This Ford Edge is far and above the most rattle and noise filled vehicle we have purchased from Ford and unfortunately lowers my sense of confidence in Ford overall.  We paid too much for this car to have what I perceive to be "cheap" fit and finish and poorly engineered fasteners.  I hope this helps anyone who may have similar noises coming from their late model Ford Edge.
Edited by CCMAYES72, 17 June 2017 - 07:06 PM.
  • WWWPerfA_ZN0W and omar302 like this
#2 OFFLINE   macbwt
macbwt
    Ford Edge Fanatic
  • Edge Platinum Member
  • 2,657 posts
  • Region:U.S. Mississippi Valley
  • Edge's Year:2011
Posted 18 June 2017 - 06:43 AM
The platform you are driving is actually a new platform for the 2nd Gen Edge but it is also a reallocated platform based from the Fusion.  So yes and no to your belief that this is a carry over from the 1st gen and 1.5 refresh of the previous Edge runs.   Since it is a redesign and use there will be new issues.
  • WWWPerfA_ZN0W likes this
#3 OFFLINE   CCMAYES72
CCMAYES72
    New Edge Member
  • Edge Member
  • 3 posts
  • Region:Decline
  • Edge's Year:2016
Posted 18 June 2017 - 11:09 AM
HI Macbwt, I was not aware, I thought it was the same as the 15. Thank you for your input.
#4 OFFLINE   MJB3
MJB3
    New Edge Member
  • Edge Member
  • 62 posts
  • Region:U.S. Pacific Coast
  • Edge's Year:2017
Posted 18 June 2017 - 11:57 AM
The 2016 is on the same platform as the 2015. The change in the platform was from 2014 to 2015.
#5 OFFLINE   haedgy
haedgy
    New Edge Member
  • Edge Member
  • 84 posts
  • Edge's Year:2016
Posted 23 July 2017 - 09:41 AM
I had the same issue. I fashioned my own buffer out of the foam pool tubes and placed them near the plastic clips under the two side panels until I bring mine in for the next oil change.
If there is a dealer solution I would just assume they fix it while it's under warranty.  Thanks for posting the solution. I found mine by just tapping the under panels with the tips of my fingers. When I did I could hear the plastic pins rattle because they are not as tight as they should be.  Also I am missing one pin on the back end of the passenger side panel.
I tried to push and tightened the pins but over time they just end up getting lose again. Once I put the buffers no more rattle. It was actually fairly faint but I could hear it when the radio was at lower volumes.
I have a better schematic of the underside that I will post tomorrow so others will know where to look or at least what the dealer should check. It sounds like you have a good dealer service dept I would stick with them! There are a lot that will tell you they looked into it but do nothing or "don't hear it"
As you can see there are a lot of items under the Edge that can rattle. Most of the time the culprit on any car maker is the larger panels. It's not isolated to just Ford when it comes to under panels rattling.
underside floor Edge
Addition: Here is a better diagram. If you search google images for tb10919A this image should come up. My issue is I am missing Clip 4, and Clip 5 keeps coming lose, probably because 4 is missing. I added numbers to the image since this is what I am going to bring to the dealer to show them where my issue is.
2015-17 Edge Large Under Panels
Edited by haedgy, 25 July 2017 - 08:10 AM.
  • WWWPerfA_ZN0W, omar302 and macbwt like this
#6 OFFLINE   shumax
shumax
    New Edge Member
  • Edge Member
  • 115 posts
  • Region:U.S. Great Lakes
  • Edge's Year:2016
Posted 07 October 2017 - 09:33 PM
Could you provide photos of the solution you came up with to resolve this issue? Thanks!
#7 OFFLINE   haedgy
haedgy
    New Edge Member
  • Edge Member
  • 84 posts
  • Edge's Year:2016
Posted 08 October 2017 - 10:04 AM
I don't have any photos. You just have to place them near the clips, and make sure you have to squeeze them in tight or wind will move them and they won't work. I just recently took the car in for it's scheduled service. The dealer told me they (Ford) doesn't have the individual clips (seems odd) but they did order a new panel for me. The new panel fixed it. If your Edge is still under warranty it won't cost a thing but you should probably narrow down what it is first. Also if you have had service recently and now hear it check the engine cover under the car I hear they get lazy sometimes and don't put it back on securely.
My original solution with the tubes worked. I tried to get my arm in as car as I could and put them close to the clips. I had tried to take pics but it's just too dark and tight in there to get a good shot.
One way to tell if it's the panel clips is to tap the panel in various locations if you hear a rattle its probably bad clips. if  you don't hear it then it maybe the plastic covers behind the panels. The issue with the edge is there are too many little things to rattle under the body.
I did have a rattle inside it was the center console plastic cover near the park brake. Fix is to put some screening spline under the side trim around it. That seams to pinch the plastic enough to stop a rattle.
Rattles drive me nuts too, some seemed to go away others were just because i like to keep things in the cup holders.
Wish I had a magic solution for it all but mostly trial and error to find these little issues.
#8 OFFLINE   shumax
shumax
    New Edge Member
  • Edge Member
  • 115 posts
  • Edge's Year:2016
Posted 08 October 2017 - 04:25 PM
Thank you so much!  Can't tell you how much I appreciate the reply.  I climbed under the car and looked and sure enough, both of those panels rattled in mine with the smallest touch with my finger tips.  From 10 years ago, I had some sound deadening material that is like sheets of rubber.  I cut small strips and wedged them in between the clips and the splash shield.  It made for a snug fit for all but one that was really loose.  Took it for a drive and the noise is gone!  On my trip back, I heard it once, but it was very faint.
I'm surprised they don't just sell the clips.  That's no good.  My vehicle has 12,000 miles on it, so I'm making an appointment tomorrow to get it looked at and replaced.
Thanks again for posting all of this.  Really calmed my nerves on a car I just bought, used, yesterday.
Shumax
Edited by shumax, 08 October 2017 - 04:32 PM.
#9 OFFLINE   CARR142
CARR142
    New Edge Member
  • Edge Member
  • 150 posts
  • Region:Decline
  • Edge's Year:Decline
Posted 08 October 2017 - 06:04 PM
Shumax you can buy these @ Amazon: (GOOACC Nylon Bumper Fastener Rivet Clips Automotive Furniture Assembly Expansion Screws Kit Auto Body Clips 8mm - 40PCS). If you need a few, let me know I will mail to you.
#10 OFFLINE   haedgy
haedgy
    New Edge Member
  • Edge Member
  • 84 posts
  • Edge's Year:2016
Posted 12 October 2017 - 12:39 PM
Not a problem. I think I had read on another post a dealer had that as a solution. so I just tried it with what I had around the house to see if that was the issue.
I have a feeling these plastic clips will wear eventually and start to loosen over time. Mine was dead quiet when I first purchased it when I took a long road trip it started making the sound. That was around 10k i am now at 15k with a new panel and all is good (for now) I may just put the spacers in there so there is less vibration on those plates when driving.
I believe the issue is the covers are made of a pressed fiber so they tend to vibrate with higher air flow like you get driving on the freeway. I always noticed it more when there was a high cross wind too.
#11 OFFLINE   REN
REN
    New Edge Member
  • Edge Member
  • 19 posts
  • Region:Canada Ontario
  • Edge's Year:2011
Posted 15 November 2017 - 02:19 PM
I too have a rattle/ buzzing sound coming from car travelling at speeds from 40-60-80km.
Attached is a sample audio of the sound in question taken from my cell phone placed on the dashboard with all windows up. Sound in question is around 9 second mark of the audio (2011 Mkx Whine -1). Sorry for the poor quality since it was from a cell phone mic.
I've also attached another audio of the sound (around 12 sec mark) which bit clearer then the previous one (2011 Mkx Whine - 2).
I really hear when I'm turning right at about 40-60-80 with a light foot on the gas feathering it.
Can someone please help me with this!
Edited by REN, 15 November 2017 - 02:20 PM.
#12 OFFLINE   enigma-2
enigma-2
    Ford Edge Fanatic
  • Edge Member
  • 2,706 posts
  • Edge's Year:2009
Posted 15 November 2017 - 02:46 PM
Try laying just under the side of the car and push up on the each of the panels. Probably one is loose.
#13 OFFLINE   REN
REN
    New Edge Member
  • Edge Member
  • 19 posts
  • Edge's Year:2011
Posted 29 November 2017 - 03:27 PM
Tried that and all is good. :(
#14 OFFLINE   REN
REN
    New Edge Member
  • Edge Member
  • 19 posts
  • Edge's Year:2011
Posted 29 November 2017 - 03:30 PM
It sounds like its in the car underneath the centre console.
#15 OFFLINE   haedgy
haedgy
    New Edge Member
  • Edge Member
  • 84 posts
  • Edge's Year:2016
Posted 19 December 2017 - 05:24 PM
I tapped the bottom panel, just pushing it won't make the sound, if you tap your finger on the panel around the pegs and you hear even the slightest rattle it's the pins. There is also a plastic panel on the sides just in front of the rear tires that can vibrate when wind speeds increase as well.
Also check door alignment if the seams are not equally spaced between the doors or the door is off some you can get a little bit of wind noise but also it will rattle the small hose. Sometimes sounds bounce off the windows of the car you think it's on the left but it's really on the right.
The panels under the car seem to be an issue for most who are hearing rattles when these vehicles hit 40MPH plus. The Edge actually is not the only car with complaints about underpanels.
#16 OFFLINE   haedgy
haedgy
    New Edge Member
  • Edge Member
  • 84 posts
  • Edge's Year:2016
Posted 20 December 2017 - 08:27 PM
Hey CARR just saw your post. Those are not the pins that are loose. The pins that were lose in the panel are part of the panel, at least that is what the dealer told me. Those 8mm pins are usually around the wheel well of the car and on the smaller plastic pieces near the wheels.
The pins on the panel are larger than 8mm, and are about 3" in length. The end that holds the panel on is about 1 1/2" in diameter.
I have yet to see any replacements.
