Turning off all exterior lights
I have a 2017 Edge Titanium and last night we went to a drive in theater. I couldn't get the lower fog lights to turn off with the vehicle running at all. I ended up tapping my rear floor mats over them. I checked the owners manual to find a fuse to pull but couldn't find one in either the under hood or in car fuse panels. Ford included an option to turn off all interior lights but not th exterior ones? Any help is appreciated.
To my knowledge, the US doesn't have any fog lights. If you're referring to the Daytime Running Lights, the only way to turn them off is to go through the menu on the instrument cluster on the left side. I forget what exactly it's under, but that's the only way to turn the daytime running lights.
There is no programming for the LED signature lights. They are hardwired and trip with RUN position. You need to pull the fuse which is Fuse 20 in the under the hood fuse block. The SM indicates this fuse also send power to the headlamp assemblies and the headlamp switch.
