Just wanted to see if this is normal operation or if I need to check into it.
When opening my Vista Roof, I push the open button quickly and let go and it opens fine. However, when closing, I pull the button and quickly let go, and the glass closes almost the whole way except maybe 1ft? And from there, it will only close if I pull the button and hold it until it is closed. If I let go it stops right then.
I just figured "express close" means you pull it once, let go, and it should completely shut on its own. At least my previous cars were like this, which is why I wonder why this one acts this way. But it stops at the exact same spot every single time.
For what it's worth, I have performed the initialization process successfully about 2 or 3 times now with the same results.
I have a 2009 MKX and that's normal operation (make certain that the kids don't have their fingers in the opening when closing.) You w also notice that the interior shade also stops short when closing. Again, normal.
Drove a 2016 Edge loaner a couple of days last week and the roof closed all the way with a single press. Don't know which years the changeover occured however.
Edited by enigma-2
