No tail lights
Lilmsbopeep
Yes I found the problem. My driver side headlight was damaged and exposed causing moisture to get into the socket shorting out the fuse. I removed the bulb and let the socket dry completely then covered it with duct tape and replaced the fuse again and it works. I will be replacing my headlight to avoid this happening again.
