Rear Doors Freezing – 2016-2017 Lincoln MKX
TSB 17-0030 REAR DOOR(S) FREEZING
Publication Date: March 16, 2017
LINCOLN: 2016-2017 MKX
ISSUE:
Some 2016-2017 MKX vehicles may exhibit one or both rear doors that are hard to open in freezing temperatures. This may be due to water entering and freezing the rear door exterior latch cable.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Remove both rear door latches and replace both rear door exterior latch cables. Refer to Workshop Manual (WSM), Section 501-14.
* It is not necessary to remove the interior door latch cable from the door latch assembly.
* It is not necessary to remove the latch from the handle reinforcement assembly.
To install, reverse the removal procedure.
PART NUMBER PART NAME
FA1Z-58266A46-B Exterior Door Latch Cable
OPERATION DESCRIPTION TIME
170030A 2016-2017 MKX Without One Touch Up/Down Rear Door Windows: Replace The Exterior Latch Cables Both (2) Rear Doors (Do Not Use With Any Other Labor Operations) 1.4 Hrs.
170030B 2016-2017 MKX With One Touch Up/Down Rear Door Windows: Replace The Exterior Latch Cables Both (2) Rear Doors Includes Time To Perform Power Door Window Initialization (Do Not Use With Any Other Labor Operations) 1.7 Hrs.
WARRANTY STATUS
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage.
Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
DEALER CODING
BASIC PART NO. CONDITION CODE
58266A46 01
TSB 17-0030 Rear Doors Freezing – 2016-2017 Lincoln MKX.pdf
