2013 Edge heater controls change and screen won't always dim
gjinc
OK, I set the heater controls to feet. When I stop for gas, when I am done and start the edge, sometimes the controls have changed.
If it were all the time I would thing it is normal.
Also I have the screen set for extra dimming, sometimes it does not dim until i go into setting and touch the + or -.
So, will the dealer be able to repair this or is this a "glitch" that will irritate me?
I assume you have MyFord Touch, this is a bug, the system restarts every about 20 hours of operation and that's when the screen dimming reverts to default. You can also touch Day or Night then go back to auto. This bug also affects the phone ringer & message tones when selecting anything other than the default. Tones will revert to default.
For the other issue, I don't recall reading about it. Try a battery disconnect to reset the electronics.
