Power steering problems
Jgaburri
On my wifes 2009 Ford Edge I have replaced bothe upper struts, both lower control arms, both inner and outer tie rods, and the rack and pinion. Once I bled the power steering fluid and started the car the horn started to blow on its own and the steering wheel now turns in both directions by itself. Has anyone seen this issue or has heard of it yet please help.
How does one pull a vacuum on the rack and pinion
With a mighty vac and some fittings. Do a quick search and the procedure will come up. Sorry i am not good at posting links.
Air in the system can cause this and the vac procedure will remove all of it. I guess some do not self bleed by turning lock to lock.
I pulled a vacuum on the system and followed the procedure in the chilton manual and it still does the same thing. Did some more testing that lead me to a possible steering wheel valve in the rack to be bad. Change the rack once again and still having the issues just not as bad was atleast able to drive the car. It is hard to run slightly and then after moving so far it goes on its own and you have to fight it then. The only thing left is a power steering pump could this be causing the issue
  • Confused 1
