Custom Search
AC Gas Leak and Smell - Condenser or Evaporator ?
  • Please log in to reply
3 replies to this topic
#1 taal2020
taal2020
    New Edge Member
  • Edge Member
  • 13 posts
  • Region:Middle East
Posted 05 April 2018 - 07:52 AM
Hi,
The gas in my ac tends to leak and finish quickly (within 2 months), accompanied by bad smell. I have been told this is most likely due to the AC cooler leak.
Would this be the condenser or the evaporator ? Has anyone else faced this problem ?
#2 omar302
omar302
    Ford Edge Addict
  • Edge Platinum Member
  • 1,949 posts
  • Edge's Year:2016
Posted 05 April 2018 - 08:33 AM
It would be the evaporator, that is inside the vehicle behind the dashboard. The complete dashboard will need to be removed to change the evaporator.
OEM part only comes as a complete assembly, about $380. Evaporator only you can go aftermarket about $60-$80. But because you have to remove complete dashboard, I would highly recommend OEM to make sure you don't need to replace anything else soon.
  • WWWPerfA_ZN0W and macbwt like this
#3 taal2020
taal2020
    New Edge Member
  • Edge Member
  • 13 posts
Posted 08 April 2018 - 02:53 AM
Thanks and appreciate the detailed explanation. The mechanic did mention that it would take 2 days to remove and fix the evaporator/cooler, and they have to remove the entire dashboard.
#4 omar302
omar302
    Ford Edge Addict
  • 1,949 posts
  • Edge's Year:2016
Posted 08 April 2018 - 03:02 AM
I just noticed you're from Oman. For your information, the dealer here in Qatar charged me about QAR 3,200/- (~330 Omani Riyals) for the complete job with OEM evaporator assembly. (that was for my older 2011 MKX)
Also, if your going ahead with the job, it would be a good time to change the Spark Plugs & PCV valve as the intake manifold was removed during replacement on my old car.
Edited by omar302, 08 April 2018 - 03:08 AM.
  • WWWPerfA_ZN0W likes this
