Custom Search
Sign In  Log in with Facebook
Create Account
Click here to signup now
Guest Message by DevFuse
Check out the Ford Edge ST Forum Here
Adding OEM hitch 2016 Ford Edge Sport
hitch oem 2016 sport
  • Please log in to reply
5 replies to this topic
#1 OFFLINE   mr_jason
mr_jason
    New Edge Member
  • Edge Member
  • 5 posts
  • Region:U.S. Great Lakes
  • Edge's Year:Decline
Posted 07 May 2018 - 09:07 AM
Over the weekend I decided to take a chance and add the oem ford hitch to my 2016 Edge sport. This meant cutting a hole in the bumper, swapping the foot sensors with the split sensors and adding the 4 pin trailer lighting. I had the draw Tite hitch and decided I didnt want to remove the heat shield bumper support or have it hang down. The only down side was fabricating the lower foot sensor mount, it wasnt a direct replacement. If you decide to do this Im not responsible for anything you do to your car.
Edited by mr_jason, 07 May 2018 - 09:10 AM.
  • WWWPerfA_ZN0W, omar302, lildisco and 1 other like this
#2 OFFLINE   ezndo
ezndo
    New Edge Member
  • Edge Member
  • 28 posts
  • Region:Decline
Posted 07 May 2018 - 03:42 PM
That looks great! I also was not a fan of how far the aftermarket hitches hang below the bumper. My 2016 is lowered w/H&R springs, so the hitch would have been even lower, approximately 7” above the ground. I would have no fear of cutting the bumper just like you did. Please post any tips, details you care to share and then I’ll decide if I want to go that route. TIA!
#3 OFFLINE   mr_jason
mr_jason
    New Edge Member
  • Edge Member
  • 5 posts
Posted 10 May 2018 - 08:44 AM
Measuring and cutting was a big worry... Mess it up and I'm buying a new bumper cover.  I made sure to measure multiple times and cut once taking my time - spent 2+ hours just cutting and measuring.  The hitch replaced the metal bumper.  I had to replace the foot activated sensors with the 'split' ones from the Titanium with hitch model and fab up a mount for the sensors.  Seems to work.  I did notice the hitch pin hole is very close to the bumper cover.  I use mostly the hitch mostly for a bike rack and getting the bike rack bolt and wrench was a little tough but doable.  Here's a few additional photos. I'm not responsible for anything you do to your car.
Edited by mr_jason, 10 May 2018 - 08:44 AM.
  • WWWPerfA_ZN0W likes this
#4 OFFLINE   akirby
akirby
    Ford Edge Legal Resident
  • Moderator
  • 10,631 posts
Posted 10 May 2018 - 09:23 AM
I added a hidden hitch to our 2016 MKX reserve and did not change the foot sensors - they still operate normally.   Maybe it's a different design than the Edge Sport.
#5 OFFLINE   mr_jason
mr_jason
    New Edge Member
  • Edge Member
  • 5 posts
Posted 10 May 2018 - 01:21 PM
The foot senors still work.  This hitch is the OEM version, it doesn't hang below the bumper or require the removal of the supporting plastic/heat shield behind the bumper.  It's also not specifically designed for the sport trim. I had an aftermarket hitch and didn't really like how hung below the bumper.
#6 OFFLINE   akirby
akirby
  • Moderator
  • 10,631 posts
Posted 10 May 2018 - 01:23 PM
I forgot the OEM hitch was higher.   That would make a difference with the sensor.
Also tagged with one or more of these keywords: hitch, oem, 2016, sport
