Custom Search
Extended SYNC Warranty?
  • Please log in to reply
10 replies to this topic
#1 OFFLINE   jasoneg
jasoneg
    New Edge Member
  • Edge Member
  • 35 posts
  • Region:U.S. Southern Atlantic
  • Edge's Year:2008
Posted 10 May 2018 - 06:22 PM
I used to own a 2014 Taurus,  I received a letter in the mail from Ford saying that they extended my Sync warranty to 5 years and unlimited mileage.  I now own a 2014 Edge.  Does the Edge have the same extended warranty from Ford that my Taurus did?  Its the same Sync with my touch system.
#2 OFFLINE   akirby
akirby
    Ford Edge Legal Resident
  • Moderator
  • 11,030 posts
Posted 10 May 2018 - 07:10 PM
I believe that applied to all MFT vehicles.
  • WWWPerfA_ZN0W and chefduane like this
#3 OFFLINE   chefduane
chefduane
    Ford Edge Enthusiast
  • Edge Platinum Member
  • 741 posts
  • Region:U.S. Southern Plains
  • Edge's Year:2011
Posted 10 May 2018 - 11:13 PM
If you go on the Etis site and type in your VIN it will tell you if you have been granted an extension on your APIM Warranty.  My suggestion is to print it out and take it with you to the dealer when/if you have an issue with your APIM  Sometime dealers 'forget' about those things.  Not disparaging ALL dealers, just some. :)
  • WWWPerfA_ZN0W likes this
#4 OFFLINE   jmr061
jmr061
    Ford Edge Member
  • Edge Member
  • 408 posts
  • Region:U.S. Great Lakes
  • Edge's Year:2016
Posted 11 May 2018 - 07:44 AM
The notice is under 12M02, it applies to all 11-14 Models with MFT/MLT and 14 is the cutoff.  It is 5 years from the in-service date of the vehicle.  You may be close to the end of your 5 years depending on the in-service date.
#5 OFFLINE   Waldo
Waldo
  • Edge Member
  • 1,041 posts
Posted 11 May 2018 - 08:15 AM
You can also register your vehicle on the FordPass app and it will tell you.
#6 OFFLINE   jasoneg
jasoneg
    New Edge Member
  • Edge Member
  • 35 posts
  • Edge's Year:2008
Posted 11 May 2018 - 03:03 PM
Sounds good!  My in service date was 2/15 so I am good on that!  It was built late 2014 and sat on the lot for a while.
Thanks everyone!
#7 OFFLINE   jasoneg
jasoneg
    New Edge Member
  • Edge Member
  • 35 posts
  • Edge's Year:2008
Posted 11 May 2018 - 05:19 PM
I went to the ETIS site and put in my vin.  It says there are "No campaign messages found"  Am I missing something?
#8 OFFLINE   jasoneg
jasoneg
    New Edge Member
  • Edge Member
  • 35 posts
  • Edge's Year:2008
Posted 11 May 2018 - 05:36 PM
Just registered vehicle on Fordpass app.  I don't see anything that says I have an extended sync (apim) warranty.
#9 OFFLINE   chefduane
chefduane
  • 741 posts
  • Edge's Year:2011
Posted 11 May 2018 - 11:54 PM
Jasoneg, then I would assume that your vehicle is not covered under the extended APIM warranty provisions.
#10 OFFLINE   jmr061
jmr061
    Ford Edge Member
  • Edge Member
  • 408 posts
  • Edge's Year:2016
Posted 12 May 2018 - 12:16 AM
If the apim has already been replaced then the extended warranty on it would no longer exist.  Have to check service or sync records for that.
Edited by jmr061, 12 May 2018 - 12:17 AM.
  • WWWPerfA_ZN0W and enigma-2 like this
#11 OFFLINE   jasoneg
jasoneg
    New Edge Member
  • Edge Member
  • 35 posts
  • Edge's Year:2008
Posted 13 May 2018 - 07:20 AM
Well,  I guess that's possible.  I am not the original owner.  But the car only had 21K miles when I got it.  I guess the APIM could have went bad that quick.
