Rear Brake Job 2009 - Pads and Rotors - Issue getting Rotors off
evh
Ok, I did some searching but I want to make sure I can get the original rotors off the rear brakes of my 2009 (216,000 miles - I know, I know). They look terrible now. I did a pad slap a few years ago. I know they will be rusted to the hubs. I am not too worried about that. I am more worried if there is something the emergency brake could have done that is going to prevent me from getting them off.
I watched one YouTube video and they only had to use a hammer. His was 2010 and things looked pretty clean.
I seem to remember trying to get the rears off my sons Ford Explorer and we could not get them off (some type of a ridge build up???)
Please advise.
Thanks!
Emergency brakes are drum brakes, so the rear rotors can present the same challenges to remove as well worn drums. I am like you, and let my rotors get real bad before changing them. I had this problem on one of my rear wheels once, and it was a combination of tapping the backside of the rotor, tapping front and back of the center of the rotor (3 and 9 o'clock if you're looking at the wheel), adjusting the park brake cable to ensure all tension was off it, and lots of wiggling the rotor back and forth.
Follow-up. I just replaced the rear rotors and pads. I just had to use a hammer and hit the rotor. I mainly hit the inside front of the rotor where the pads DON'T touch the rotor. About 5 or 6 good hits and the rotors came right off. No issues. Also note these are 9 year old original rotors used in the salty north.
