Tight power steering
Ajbarger
So my power steering pressure line blew on way home from work this weekend. Thankfully was only a couple blocks from home. Steering was fine as I didn't lose all fluid before getting home. I replaced line this weekend and tried to make sure no air was still in lines. Now the steering is very tight. I didn't read to realize it called for ATF and I used penzoil power steering fluid with stop leak. Could wrong fluid be cause or is it likely something different? Thanks
