Flat towing
Kenscomet
It makes no difference electrically whether you disconnect the positive or negative cable. Both are necessary for current to flow. The reason for disconnecting the negative is for safety... if you happen to bang your wrench against something metal while disconnecting the negative cable, nothing will happen. But if you happen to bang your wrench against something metal while disconnecting the positive cable (while the negative is still connected) you would create a massive and very dangerous short circuit.
