H&R Suspension Set Up
I was on the H&R website and I was looking at the H&R Edge. I found the following info for the suspension set-Up:
H&R Ford Edge H&R 2007 Ford Edge Project
Chassis/Suspension:
:: H&R Sport Springs
o Lowers 1.5-2.0 inches on average
o Superb ride quality
H&R Sport Springs offer the handling characteristics and aggressive appearance that you’ve been looking for, without the harsh ride characteristics of less-advanced spring systems. H&R Sport Springs feature more control and are engineered for the street, making them comfortable and fun to drive. H&R Sport Springs are crafted from a special 54SiCr6 spring steel to ensure quality and performance.
:: H&R Trak+ Wheel Spacers
If you've ever seen a sleek, European sedan with that oh-so-low street stance and a bulging wheel / tire combo that fits perfectly in the wheel wells, chances are that car was fitted with H&R TRAK+® Wheel Spacers. TRAK+® Wheel Spacers make your existing tires and wheels appear wider by moving the wheel out from the hub, providing both performance and appearance improvements. Whether you want improved handling, increased safety or simply desire your car to make a statement about your individual style, TRAK+® Wheel Spacers can help you accomplish your goal.
:: H&R Triple C Camber Adjustment Bolts
Whenever you lower a vehicle’s ride height, negative camber is increased –– how much depends on the vehicle and the reduction in ride height. H&R ‘Triple C’ Camber Adjustment Bolts are a simple, yet very effective means of removing excessive camber, adjusting your vehicle’s camber settings, or even correcting small side-to-side camber variations for precise alignment.
Consisting of a pair of specially-designed bolts, H&R patented ‘Triple C’ Camber Adjustment Bolts replace the original upper fastening bolts on McPherson strut applications. As the bolt is turned, a small cam eccentric alters the vehicle’s camber, allowing adjustments from 0-3 degrees, positive or negative.
Installation takes only minutes with readily available hand tools, and benefits include increased tire life, improved tracking and the ability to dial in more camber for weekend track events.
Quite simply, H&R ‘Triple C’ Camber Adjustment Bolts are a great value. No other single suspension modification can yield such impressive results with such a small investment in time and money –– and you can do it yourself.
Does anyone have this Set-Up
