Undercarriage sound
07 Edge................going on since it was brand new. It sounds as though I have something loose in the suspension, like a shock or strut. It's been checked every time I have it serviced, nothing found.
This is not a severe sound, just subtle, and it seems to decrease as the vehicle is driven a few miles, like it the tires are hard when cold. (Hankooks) This Edge does not have a quite, smooth suspension system.
Anyone have similar experiences???
  • 1 year later...
I have a simular sound. I noticed it after the dealer had to fix a right front drive shaft seal. It sounds like the rubber at the top of the strut is rubbing wear it is touching the mounting point. I wonder if this needs to be lube before they put it back on after fixing the shaft seal? I hear it more when I first start to drive it or turning while coming into the driveway. Anyone have an idea for helping with this?
