Custom Search
Sign In  Log in with Facebook
Create Account
Click here to signup now
Guest Message by DevFuse
Check out the Ford Edge ST Forum Here
ignition taking a while to turn over
  • Please log in to reply
7 replies to this topic
#1 OFFLINE   christy719
christy719
    New Edge Member
  • Edge Member
  • 2 posts
Posted 14 July 2010 - 08:29 PM
I have a 2010 Ford Edge and have noticed an intermitent problem when starting. Usually it starts right up, but sometimes after the engine is warm and I have parked for about 20 minutes or so I go to start the car and it takes a few more seconds for the engine to turn over. It is really hard to describe but don't think this is normal. Has anyone else experienced this? I have been using high Octane gas in it, I don't know if this could be doing it.
#2 OFFLINE   L1TECH
L1TECH
    New Edge Member
  • Edge Member
  • 136 posts
Posted 15 July 2010 - 08:36 AM
First off, stop using the high octane fuel as it is doing absolutely nothing for your vehcle and is only draining your wallet. Now when you say takes a while to turn over do you mean that when you turn the key the engine doesn't crank or you turn the key, the engine cranks but takes a few seconds to start....
#3 OFFLINE   christy719
christy719
    New Edge Member
  • Edge Member
  • 2 posts
Posted 17 July 2010 - 07:19 AM
The engine cranks and will turn over but takes a while. I read in the manual that high octane gas is not good for the engine it is designed for regular gas and could cause starting, knocking and running rough. I should of read this before hand. I hope this is all it is the tank is almost empty and going to go back to 87. I also notice sometimes when going into reverse or drive it goes into gear hard. I spoke with someone else with the same year edge and she is feeling the same thing. I am going to try to find out if there is any TCB's about that problem. Other than that it runs great. Getting ready to take a 13 hour road trip and the starting issue is making me a little nervous.
#4 OFFLINE   claas900
claas900
    New Edge Member
  • Edge Member
  • 53 posts
Posted 17 July 2010 - 03:41 PM
Ours dose the same thing every now and then. It cranks over fast like normal just takes a wile to fire and take off.
#5 OFFLINE   L1TECH
L1TECH
    New Edge Member
  • Edge Member
  • 136 posts
Posted 19 July 2010 - 08:38 AM
For the extended cranking issue my first thought is a fuel pump issue. There is a check valve in the fule pump that prevents fuel from backflowing into the tank when the vehicle is shut off so it starts faster. A fuel pressure test is in order to see what is happenign when the vehicle is shut off.
#6 OFFLINE   claas900
claas900
    New Edge Member
  • Edge Member
  • 53 posts
Posted 20 July 2010 - 04:11 PM
Yeah I was thinking it was a fuel issue also. I thought regulator first. I didn't know there was a check valve in the pump tho.
#7 OFFLINE   ajecarae199
ajecarae199
    New Edge Member
  • Edge Member
  • 1 posts
  • Region:U.S. Mississippi Valley
  • Edge's Year:2010
Posted 26 October 2016 - 07:27 PM
I'm having the same problem when starting my edge. Have you be able to resolve the issue with your vehicle?
#8 OFFLINE   PaulSchott
PaulSchott
    Ford Edge Member
  • Edge Member
  • 398 posts
  • Region:U.S. Northeast
  • Edge's Year:2007
Posted 31 October 2016 - 11:26 AM
You can see if the problem is the pump by turning the ignition on and letting the pump run until it stops pumping and the system is pressurized. Turn the key to start after and if the car starts normally it is the pump check valve bleeding down.
  • WWWPerfA_ZN0W likes this
