- Start new topics and reply to others
- Subscribe to topics and forums to get email updates
- Get your own profile page and make new friends
- Send personal messages to other members
- Create a photo album and post images. . .and more!
2011 sport 3.7L engine noise
#1
OFFLINE
Posted 15 January 2011 - 10:00 PM
level it was full. There is a ticking noise that is coming from the injectors which is normal. The noise I heard sounded like a lifter noise. Has anyone else come across this issue. You
know that ford is probably going to say that this is a design characteristic. Has anyone else experienced this issue. Thanks for your input.
#2
OFFLINE
Posted 25 January 2011 - 11:27 PM
Ford has issued a "Special Service Message" about this kind of concern. You might want to enquire at your dealer.
#3
OFFLINE
Posted 27 January 2011 - 01:20 AM
Pro 5.0
Thanks for the response B_Bob.
Ford claims that this noise will not cause any engine damage, Which just tells me that they don't know what is causing it.
It would be a shame to crack into a brand new engine. We will just have to wait and see what TSB comes out for this. These
engines are just put into production without being properly tested. Just what everyone wants a $ 50,000.00 vehicle that has
all the bells and whistles, but an engine that sounds like it has 200,000 plus kms. Quality is job 1 YEAH RIGHT!
#4
OFFLINE
Posted 27 January 2011 - 08:55 PM
These engine have solid bucket type followers They are adjustable, some slight ticking may be heard under hood, but I wouldn't expect to hear it with the hood shut.
The cams have to come out to complete adjustment, as all clearances are measured, then the buckets removed, shims measured and the proper sized shim to set clearance is installed.
#5
OFFLINE
Posted 28 January 2011 - 06:40 PM
The noise is not related to an adjustment issue as the noise is variable and not a constant.These engine have solid bucket type followers They are adjustable, some slight ticking may be heard under hood, but I wouldn't expect to hear it with the hood shut.
I beleive that it may be related to some issue with the design characteristics of the variable valve timing.
Even with the hood closed the noise is very audible from inside the vehicle. Ford says that the noise will happen
at start up and go away. This is not the case there is a design issue somewhere. It may be related to the cam phasers
or some part in the valvetrain, it may possibly have something to do with the oil passages in the cylinder heads. Who knows
at this point. It is 100% related to the 3.7L engine as I have heard this same noise in 5 other brand new edges and lincoln mkx models.
This condition may not be heard by the average driver as their ears may not be tuned in to such noises from the engine.
#6
OFFLINE
Posted 28 January 2011 - 09:21 PM
Ah, ok. A different sound than a "lifter" type noise. Yes, it could be the cam phasers.
I've gone through the SI on the 3.7, and the way the timing chains are set up, there is 1 primary chain and 2 secondary chains that are driven off the intake cams behind the actual phaser itself.
I did not notice any odd sounds coming from the motor, when I was looking at a sport several months ago, but I wasn't really listening.
No bulletins or messages about it that I can find.
#7
OFFLINE
Posted 17 June 2011 - 08:09 PM
We just took delivery of our 2011 edge with a 3.7L V6 engine. Got the vehicle home and noticed a slight ticking noise coming from the engine at idle, shut off vehicle and checked the oil
#8
OFFLINE
Posted 17 June 2011 - 08:11 PM
My 2011 edge with 5300 miles on it has metal tapping noise on start up, I took it to the dealer a month ago and they said that they could not hear it. Over the next few weeks the noise increased in volume and the duration of time before it subsided, so i took it back to the dealer and left it there so I could return when the engine would be cold and have the tech be there with me and listen for the noise together. This time he heard it and then he stated that it did not sound normal for a new engine but he thought Ford would decline to do anything about it. When I picked it up the next day (it was also there for a defective interior trim issue) the service writer produced a "497000-engine noise concern" bulletin. This stated that some 2011 edges may have a tick or metal tapping noise upon start up and warm up but it would not damage engine or cause long term durability concerns and engineering is investigating this concern and recommends no repairs be attempted.
It seems to me that if Ford is investigating it, then they don't know what it is, and therefore how could they know how this might affect the engine over time.
#9
OFFLINE
Posted 01 February 2012 - 05:44 PM
- Lowery89 likes this
#10
OFFLINE
Posted 12 February 2012 - 10:21 PM
Thanks
Scott
#11
OFFLINE
Posted 13 February 2012 - 12:08 AM
Has anyone gotten anywhere with the noise? I believe mine is getting louder and I am getting more concerned and of course the dealers tell me it is normal!
Thanks
Scott
There is a fix for this it is a oasis tsb 11 11 15. It involves putting oil restrictors into the camshaft on the cylinder head closest to the front of the vehicle.
It raises the oil pressure to eliminate the ticking.
Repair kit # AT4Z - 6A296 - A . Just had it done and it fixed the problem, I can't beleive that so many people have viewed this post and no one had any answers it has been over a year.
Well I started this post and I just ended it. Good luck to all.
#12
OFFLINE
Posted 13 February 2012 - 02:25 PM
I have 2 potential solutions to this problem:
1) Crank the radio
2) Have extended warranty.
Seriously, I haven't heard it on mine, am I pretty tuned in to what's going on in my vehicles. Not saying it isn't there, but if it is on mine, I don't hear it. Thanks for providing a solution!!
Edited by richy, 13 February 2012 - 02:27 PM.
#13
OFFLINE
Posted 13 February 2012 - 04:41 PM
How can I get this TSB? I just had a quick look at motorcraftservice.com and www-odi.nhtsa.dot.gov/tsbs/ but I did not find it. :-(There is a fix for this it is a oasis tsb 11 11 15. It involves putting oil restrictors into the camshaft on the cylinder head closest to the front of the vehicle.
Thx for any hint.
#14
OFFLINE
Posted 13 February 2012 - 05:15 PM
#15
OFFLINE
Posted 13 February 2012 - 11:14 PM
The original description of the ticking is oasis tsb 11 11 15It's actually TSB 12-1-17
The repair tsb is 12 1 17
Sorry for any confusion but these are the numbers stated on my work order.
#16
OFFLINE
Posted 13 February 2012 - 11:34 PM
#17
OFFLINE
Posted 13 February 2012 - 11:48 PM
I only said that because I looked it up in oasis.
No worries
My goal was to inform anyone having this problem that there is a fix for it.
It is very frustrating when you spend your hard earned money on something BRAND NEW and you are faced with this type of problem.
We buy new so that we don't have to deal with such issues.
I hope everyone can benefit from this post.
#18
OFFLINE
Posted 14 February 2012 - 07:39 AM
Can someone tell me where to pull up this tsb??????????No worries
#19
OFFLINE
Posted 14 February 2012 - 10:42 PM
Don't waste your time trying to look it up.Can someone tell me where to pull up this tsb??????????
Simply take it to your dealer and get it fixed.
It's free.
#20
OFFLINE
Posted 19 November 2012 - 01:27 PM
