3.7L Chipped?
MikeCho
  • 1 year later...
'13 Edge Sport, 3.7L, FWD, with Jet Performance Module #71103 (Auto Anything), stock air intake/box, w/Green Filter USA filter #7035 (10%+/- air flow then K&N) @ 10 hp & .5 to 1 mpg gain on 87 octane gas (expecting better w/93 octane). Good/stock driving characteristics & throttle response, slightly better sit-of-the-pants acceleration thru-out the power band. No ill effects. Next test, 93 octane on this set-up.
Then, add a smoother/freer flowing K&N CAI w/Green Filter USA filter #2313 & Jet Module to see if I realize any added benefits @ acceleration, hp, mpg, etc.
As an SCT dealer with my Mustang & Hemi CAI's business, SCT has no tune or projected date for one for the '12-'13's and with no "larger then stock" CAI/MAF w/tune on the market, this is the best set-up I've found w/o a custom dyno tune. I'll let you know my findings as I play around here.
NOTE: Ford PCM's (on board computers) have a adaptive learning phase for changes to air/fuel/timing perimeters & driving habits, usually 5 to 7 normal drive cycles. When you install a CAI, high flow filter, and/or performance module, tune @ "unhook the battery" to cancel previous perimeters learned/used and drive 5 to 7 normal driving cycles, to better see/feel any mpg difference, performance gains, throttle response, etc.
Edited by dark sport
I have heard of people on this forum speak very highly of the "Green USA Filter's".. Unfortunately, I am only able to locate the Part #7035 on their website, which is just a stock air intake box filter.. Does anyone know if there is a green filter that will fit the K&N intake for an 07 Edge? I am guessing, just the dimensions will be needed, I am at work and don't have them off the K&N Filter, but maybe someone here has already done what I am asking.
Green Filter USA filter #2313, is replacement for K&N CAI filter #RF-1048 @ 6" ID opening, 5.5" long.
https://www.greenfilterusa.com/store/2313
Green Filter USA, 100% cotton, cleanable/reoilable filters use deeper air filter pleats than other filters with a pleated design, creating 20% more filtration surface. Plus other benefits over K&N. See review below:
http://forums.focaljet.com/fswerks/669995-itg-green-air-filter-details.html
Here's a simple video from their website. We've dynoed Mustangs with various filters and found same results.
  • 1 year later...
BTW Mike are you the actor or just have the same name? Anyway you can get a SCT tuner from Fastpartsnetwork.com Torrie makes tunes that he can customize for your particular set up. It costs about 400 for the tuner and you'll get 3 tunes. He can make up to ten tunes per tuner. The best part is that it take 5 minutes to tune the car or bring it back to stock.
  • 2 years later...
  • 3 months later...
Yesterday, I installed an sct X4 with 87 octane tune on my '11 Sport. Haven't driven it enough to know what my fuel mileage is doing, but it sure is a LOT more fun to drive!
My X4 should be in this week for my 14 Sport. I'm running 93 octane so we'll see what happens.
