Content Count
2,657 -
Everything posted by 1004ron
TSB 22-2181 - 2015-2017 Edge 2.7L EcoBoost, 2016-2018 MKX 2.7L EcoBoost + Other Models - Oil Pan Leaking
1004ron replied to Haz's topic in Recalls, TSBs & Warranty
As far as I can tell those that have had their oil pans done correctly as per the procedure haven't had any issues, so I question the skills of your dealership. It might also be a good idea to contact Ford Customer service and let them know your concerns and possibly with that on record it might be covered if it leaked again, and I'd definitely take a different dealership. -
Group 65 Battery in 2nd Gen Possible?
1004ron replied to omar302's topic in 2015+ Edge & MKX Generation II
@omar302 Its been a while - what battery did you end up installing? -
Group 65 Battery in 2nd Gen Possible? - 2015+ Edge & MKX Generation II - Ford Edge Forum
2020 SEL AWD RDU Fluid - Redline lightweight Shockproof work?
1004ron replied to lildisco's topic in All Wheel Drive (AWD)
I've got 90K miles on mine and have changed the RDU oil three times and the above mentioned method extracts just about the full volume of oil. The last fill I used Amsoil SEVERE GEARĀ® 75W-90 My RDU oil has looked like new each time. -
1004ron replied to WWWPerfA_ZN0W's topic in Accessories & Modifications
Actually a good sign that the catch can is working well. -
That's what mine looks like and even more of it in the cold months. -
Give the search feature a try. -
GSB 23-7003 - Various Vehicles - Paint And Bumper Concern Analysis
My 2017 Sport paint is completely etched from the acid rain from the power plant that I work at. I'm very surprised that there's any form of warranty on this - need to look what the fine print says about this. -
Welcome. What's the mileage? What's the service history - oil change interval - what oil used - what oil filter used - who does the oil changes? I would trust the oil pressure switch is functioning correctly unless proven otherwise by a gauge.
Fluttering Noise from Undercarriage and Dashboad Rattle
1004ron replied to CCMAYES72's topic in Brakes, Chassis & Suspension
No, not a "pushnut" - its one of these: Self-Threading Nuts - Washer Type https://www.amazon.com/Dorman-Help-45384-Thread-Cutting/dp/B000COCTDK/ref=sr_1_3?crid=1P1YYZBZNSRU2&keywords=Thread+Cutting+Nut&qid=1676246531&s=industrial&sprefix=thread+cutting+nut%2Cindustrial%2C121&sr=1-3- 77 replies
- 1
- dash noise
- dash rattle
(and 4 more)
Tagged with:
They're pressed steel nuts. Maybe @Haz can identify them for you and where they can be bought.- 77 replies
- 1
- dash noise
- dash rattle
(and 4 more)
Tagged with:
3rd Brake light/visor removal 2019 Edge Titanium
1004ron replied to EMT6996's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Could you post a link to this. -
https://www.youtube.com/watch?v=kUtyYU15Fk4 -
Need Help -- 2008 Limited Battery Drain Problem
1004ron replied to Peveto's topic in 2008 Edge & MKX
I'd get that new battery load tested. -
What's the mileage? What's the oil change history - oil used and miles between changes ?
What are you using to read the codes? - I ask because an app that I trusted didn't read codes that were present and showed using ForscanLite. You could try a shot of starter fluid - that would identify if it was a fuel delivery issue and if it has spark.
Attention - there's an uptick in accounts being hacked
1004ron posted a topic in Forum Help & Site Suggestions
The past few weeks there's been a few accounts obviously hacked and used to post malicious links. If you see such posts best you don't let your curiosity and click on the links, and use the "report post" button. The only option was to ban the hacked users accounts. This would be a good time to strengthen your account password. -
1004ron replied to 1004ron's topic in Forum Help & Site Suggestions
Hacker with Russian IP address has been busy today, hacked a couple of accounts of members that joined back in 2012. -
There's more than one way of doing the relearn, and with this M/Y they would self learn just by driving it for about 20 miles. I use the "wake-up" device in the link that you posted because its the quicker more practical way of doing it.
VOLKS WAGEN - SUICIDE BOMBER - YouTube VW commercial features suicide bomber? - YouTube
LED turn signal bulbs flickering
1004ron replied to Duke Silver's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
The driver electronics need the supply voltage to be steady above a certain threshold and when in dim mode there's probably just not enough to hold it on, also many vehicles these days use Pulse Width Modulation (PWM) to control the brightness of a lamp, which is more like AC than DC which the LED's need. -
I expect the front turn signals are the same as my 2017 Sport, the turn signals are dim with the parks on and switch between dim and bright when the turn signal is on, so the LED's aren't going to work. -
What's the mileage and service history? The first two codes are related to the Variable Valve Timing and typical of engines that haven't been maintained - infrequent oil changes. The third code indicates a poor CAT performance, which would be premature for a 2017 so could be oil burning that lead to that.
From the album: Edge Sport
