bickyii
Ford Edge 2011, Clicking noise from front driver side wheel while applying brakes
Hi,
I bought an Edge 2011 with 64K KMs 2 months ago from dealership. Dealer said that they did resurfacing of brakes before giving it to me.
Whenever I apply brakes softly I hear a clicking noise from driver side wheel. Its a rhythmic noise like something is touching to rotor and making that click noise while it rotates.
Anyone has any idea what problem it could be?? Rotors & pads looks good.
Thanks in advance
Share this post
Link to post
So, no noise when applying the brakes hard? Probably a loose brake pad OR a sticking caliper causing uneven contact. Assuming the rotors were turned properly and didn't end up being lightly grooved.
Share this post
Link to post
Thanks for replying, yea while pressing brake harder there is no noise, possibly it stop quickly and there is not much time I can hear it.
It might be due to a loose caliper. The outer side of rotor is pretty smooth like new, couldnt see the inner side without taking tire out.
I was wondering its not serious and I can wait till my next service due in a month, will get my brakes checked and tires rotation done.
Share this post
Link to post
So, this noise was being so annoying and last weekend I decided to open up brake myself. (In past I have replaced brake rotors, pads on my old & friends car)
I opened up tire & disassembled all the brake parts, Cleaned callipers & brake parks with break cleaner, there was rust on the callipers where break pads move. After cleaning all the rust I applied grease on moving parts (I shouldnt have applied that, but I didnt know what was actual paste kind of thing I should apply). Assembled the parts again and wowwwwwwww....
The annoying noise was gone and it drives like brand new again..
hope it will help someone.
Thank you.
Share this post
Link to post
Goes to show. When replacing brake pads/rotors, ALWAYS ALWAYS ALWAYS, clean everything around them. It is your opportunity to fix anything that cause less than optimal function.
Share this post
Link to post
I have same sort of problem with my edge-SE-2013, 43K km.
When i press the brakes hard, sudden heavy Dak Dak sound same.
give it to dealer to sort out the problem, but they remain Clueless about the prob.
Anyone experience this?
Share this post
Link to post
I would check the wheel bearing axel nut and make sure it is at spec for Ft lbs. Then torque it more about another 10. Or replace the wheel bearing. Had the same problem and once retorqed tighter the noise stopped.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
