2015 Edge Sport with P25B0 trouble code
The f150 reference. Could be a PCM calibration error.
A Rousch manual says possibly "P25B0 Fuel Level Sensor “A” Stuck"
Ford E-Series and F-Series Products
Description
The SRM reads Fuel Level Sender (FLS) input and broadcasts it to the IC and PCM. If the vehicle is driven a considerable distance and the FLS value doesn't change, the fault is set.
Possible Causes
Fuel Level Sender fault
Wire fault between FLS and SRM
SRM fault
Symptom
The driver is unaware of a low fuel condition.
tsb15-0040.pdf
Edited by WWWPerfA_ZN0W
