Invatation: please join me in the 1/4 mile 12 second drag racing club
037
It was a hot day around 100* and traction was a problem. The heat made for thin air and the track was hot and greasy. You can here my tires fighting for grip in 4th gear in the M4 clip. I will not give my times but I was able to outrun a Shelby GT350 a M4 BMW and a Camaro SS . Lets just say I was in the 12's.
So where are the slips showing you in the 12's?
I found this chart that will correct your time and MPH to sea level. That is if you know the DA or just the track altitude when you made your run. It is interesting to see how fast that run would have been if at sea level on a perfect day. This was the only chart I could find for turbo engines. It is not perfect for the EcoBoost but it is close enough for fun. Again, this is just for fun and the numbers are close but not exact.
To convert your timeslip ET and MPH to sea level.
Multiply applicable factor times your ET or MPH.
(Example: You ran a 14.4 @ 103 MPH at 5000 DA track. The correction factors are .9367 and 1.0661 for 5000'. (14.4 * .9367) = 13.50 , (103 * 1.0661) = 109.80 MPH. So the correct time slip would be 13.50 @ 109.80 MPH at sea level)
For Modified Supercharged and Turbocharged Engines
Altitude (in feet) Elapsed Time Factor MPH Factor
1200 .9967 1.0034
1300 .9961 1.0039
1400 .9955 1.0045
1500 .9950 1.0050
1600 .9944 1.0055
1700 .9938 1.0061
1800 .9932 1.0066
1900 .9927 1.0072
2000 .9921 1.0077
2100 .9915 1.0082
2200 .9909 1.0088
2300 .9904 1.0093
2400 .9898 1.0098
2500 .9892 1.0104
2600 .9886 1.0109
2700 .9881 1.0115
2800 .9875 1.0120
2900 .9869 1.0125
3000 .9863 1.0131
3100 .9858 1.0136
3200 .9852 1.0142
3300 .9846 1.0147
3400 .9840 1.0152
3500 .9835 1.0158
3600 .9829 1.0163
3700 .9823 1.0168
3800 .9817 1.0174
3900 .9812 1.0179
4000 .9806 1.0185
4100 .9800 1.0190
4200 .9794 1.0195
4300 .9789 1.0201
4400 .9783 1.0206
4500 .9777 1.0212
4600 .9771 1.0217
4700 .9766 1.0222
4800 .9760 1.0228
4900 .9754 1.0233
5000 .9748 1.0238
5100 .9743 1.0244
5200 .9737 1.0249
5300 .9731 1.0255
5400 .9725 1.0260
5500 .9720 1.0265
5600 .9714 1.0271
5700 .9708 1.0276
5800 .9702 1.0281
5900 .9697 1.0287
6000 .9691 1.0292
Edited by Xtra
Xtra, my best 60ft on 93 was 1.82
That is fast ! The track must have been sticky to get that and you hooked up good. If you use the correction chart above your 12.7 would be even faster . Do you know the DA when you ran that record? I would be interested in seeing what you would have run at sea level.
Edited by Xtra
It was -1100 or so DA for the 12.7, so not going faster if you go to 0 DA unfortunately.
What was your time and DA?
I am just learning about DA and how it effects the car. Unfortunately I don't know the DA the one day I tested. All I know is the elevation of the track is 1,158.1 FT and it was 100*F and the car fought for traction.. I found that the track has a site with the DA by the hour. Looking at 93*F today and a 3,938 DA at the track. At 100*F it would be have been more than 4,000, -1100 DA thats nuts. My 60 ft was 1.942 that day. I have decided that there is no reason to race the car when it is over 90*F so it may be awhile before I run again.
Edited by Xtra
Ah, I see now what you ran. We’ll go when you can when it’s cooler out and good luck! Hope you can dip into the 12’s soon.
Take off was smooth but I got wheel hop on the 1-2 shift you can hear it on the video in the car. It was my first time on a drag strip in 20 years so I was rusty with the launch and the lights. The car even broke the tires on the 3-4 shift just before the finish line and you can here that on the M4 phone video. I had good top end mph for hot 4000+DA day. I have a 60duro RMM, 21 inch Pilot Sport 4S summer tires.and H&R spoings.
Edited by Xtra
What tire pressure are you running on those ps4s you should not be getting wheel spin after take off with those.
Ive got much more power than the edge on my rs and I run those and dont get any wheel spin after launch. It could be the awd system is just better but I feel like you have something else going on if you are getting it going into 3rd.
Xtra, I'm not one that cares all that much for 0-60'(!) or judge strip results, more interested in rolling X to Y, top end, ability to take curves. What was your top end MPH?
