karpcbk
PTU drain plug
Recently purchased a brand new Edge Sport. Got it home and over the course of a week, I was noticing red transmission fluid on my garage floor. Took it in last Friday and they confirmed that it was a bad PTU leaking. It only has 400 miles on it and I'm fairly upset that PTU failures are still an issue. What is the longevity of these PTU's after they have been replaced? Is this going to be an ongoing thing?
My 2017 Sport has 29,000 on the clock and no issues with the PTU, and I've read about others with high mileage, some having done maintenance and some zero maintenance, with no issues.
Edited by 1004ron
Share this post
Link to post
That's good to know! I hope this will be the last time it needs any sort of maintenance. Otherwise it is a stellar vehicle!
Share this post
Link to post
2016 Tightanium with 30k. No leaks. Oil changed at 28k and looked fine. Probably didn’t need to do it but since I have a drain plug I’m not taking any chances.
Share this post
Link to post
I also just recently performed a PTU and RDU oil replacement. The first time the oil changes were done was at 80, 000 KM at the dealership. The second was done by myself at 167,000km. The PTU was darker than the new oil, but flowed nicely and probably could have stayed in there longer. The PTU was surprisingly easier to get out than the RDU. The RDU I struggled to get a hose in there to suck out the old fluid, I just couldn't get the right angle no matter what I tried. I eventually only got 1/2" liter of fluid out of the RDU. Neither fluid really required servicing, but it's done and gives me a piece of mind for the time being.
Share this post
Link to post
Just a question/comment - (previous member but lost sig-nin so now new again):
My 2014, 3.5 TPU was serviced at 14K thanks to this forum. While I was concerned over this flaw, and the internal $1700 water pump issue, I decided to go ahead with the purchase. I had no drippage or TPU leaks, but wanted to see what the condition was.
The Ford dealer I bought from (2 yr trade in ??) knew about the TPU, even though their service dept said they’d only done “a few” replacements. For $100 they changed the fluid, it (gear lube) was fine. They showed it to me, normal 75-90 weight looking stuff.
Fast forward, now it has 44K, and I am going to get it and the coolant changed. The local (moved to NC) Ford dealer service advisor said he’s never heard of TPU fluid being serviced and said “we dont do it’. Thanks fella, maybe time to read the forums.
What do you think of letting my nearby Firestone change it? I have an ESP (Ford) thats good till 2020 and don’t want to invalidate it by having a non-Ford fluid used.
Or I can drive 50 miles and try another Ford dealer...
Share this post
Link to post
As long as the Firestone center has a good reputation for driveline servicing (check YELP.com for example), why not. Pretty simple process of drain/fill since no flushing can be done. Ask them to use Motorcraft PTU 75W140 fluid if you are worried about non-Motorcraft fluid while under warranty.
The key to success in a dealership is to talk to the trans tech directly if the service advisor says no. Explain to the tech what you want done, and they can likely get it done for you. Failing that, try a Lincoln dealership, odds are better they WILL service the PTU.
Or you can try to find a shop that does BG Drive Line Servicing. Might still have to explain to them what you want done, but they should be able to figure it out also.
https://www.bgprod.com/find-a-shop/
If you are in/near Raleigh NC for example
  • The Car Place
    4813 Hargrove Road
    Raleigh, NC 27616
    919-878-5600
  • AAA Car Care Center
    4618 Atlantic Avenue
    Raleigh, NC 27612
    919-719-1490
    6014 Glenwood Ave.
    Raleigh, NC 27612
    919-832-5907
  • Capital Ford-Millbrook Rd
    2807 Millbrook Rd.
    Raleigh, NC 27616
    919-790-4700
  • Sir Walter Chevrolet
    8501 Glenwood Avenue
    Raleigh, NC 27612
    919-787-3700
  • Quail Corners Shell
    1326 East Millbrook Rd
    Raleigh, NC 27609
    919-876-2235
  • Atlantic Avenue Tire & Service
    2131 Harrod Street
    Raleigh, NC 27604
    919-872-6506
  • Black's Tire & Auto #35
    1823 East Millbrook Rd
    Raleigh, NC 27609
    919-878-1166
  • Capital Ford, Inc.
    4900 Capital Blvd
    Raleigh, NC 27616
    919-790-4600
    2807 Millbrook Rd.
    Raleigh, NC 27616
    919-790-4700
  • Capital Ford Quick Lane
    4900 Capital Blvd
    RALEIGH, NC 27616
    919-790-4748
  • Chapel Hill Tire, Inc
    2131 Harrod Street
    Raleigh, NC 27604
    919-872-0786
  • Capital Chevrolet
    1820 Capital Blvd
    raleigh, NC 27604
    919-573-5252
Share this post
Link to post
PTU
If Firestone is a quick-lube or tire change place, I'd not allow them to touch any of my vehicles, ..... I'd take it to a reputable independent service centre.
The use of non-Ford fluid has no impact on your warranty if it meets or exceeds the Ford's spec - Ford has serviced my vehicle with non-Ford fluid that I provided.
Edited by 1004ron
Share this post
Link to post
Ok thanks WWWPerfa... I’m about 50 miles west of Raleigh but can either call some of those places or simply call around and see if a dealer can do it. Although Firestone Care is a national chain, I’d go to Ford first.
Share this post
Link to post
Check for a local transmission shop. They have the equipment and are usually contentious.
I had to talk directly to the technician at my local Ford dealer. Service reps are sales reps, NOT technicians. Tech came out, i told him what I wanted and he sure, no problem. He through out 1/2 hour and a can of lubericant (even though it only used a few ounces). $80 total. Tell them they can use the same pump they use to service the rear axles.
(Also mention that Ford has a service procedure based on towing and driving through deep water.)
Share this post
Link to post
Are you referring to the RDU?
If so, the RDU takes 75W90 and the PTU 75-140
Maybe you're referring to the extractor equipment.
Edited by 1004ron
Share this post
Link to post
Dealer used the same extractor as they use for rear axle.
Big honker of a machine. Has to roll around on casters.
Share this post
Link to post
I have spent well over two months going over the info in this and other Ford forums and have reached a dismal conclusion. This PTU problem has gone on for over a decade with Ford just watching and not acting. When a manufacturer has a problem and they all do, address it and solve it. Put an engineering team on it and solve the problem! This PTU problem has really highlighted a serious problem with Ford in general, and that is the unwillingness to identify and address major problems and the lack of warranty support. I don't want to buy from a car from a company like that. Forget the 2019 Edge... there are too many other choices out there and I will not have to support Ford in the process.
Ford should be ashamed of it's lack of integrity, which is so clearly displayed across all the forums.
Even though I agree that Ford has sat on this (and many other defects like 2 piece spark plugs in v8 engines in the early to mid 2000’s, the cam phasers on 5.4 Tritons, the 6.0 diesel debacle...) tell me what manufacturor has not done something akin, if not in quantity... I have owned Toyotas and for years they were very high on quality... well tell that to Sienna minivan owners and their $1100 power sliding doors (apiece). Tell that to Honda Odysee owners in the early 2000’s who had to pony up $5K plus for their defective transmissions as well as their own power sliding door issues... Tell that to Chrysler owners with their myriad of complaints, GM and their piston slap of 2007, newer transmission issues all over their pickup forums..., Subaru Boxer engines with head gaskets, the list goes on and on...
My point is that you can find crap build quality on every maker, and I am not even starting on BMW Jaguar and Mercedes with their “vaunted” European technologies...
If you like a particular product, do your due diligence (so easy these days with forums) and read up. Then make an informed decision. Swearing off a car maker due to a problem or problematic area is, well, kinda uninformed. It’s everywhere in todays business community. Almost no firm does what’s right due to the bottom line being the driving force. If an executive were to fess up and recall or repair problems, they’d be hit with multiple claims and lawsuits from past unsatisfied customers and even shareholders whose stock prices have now been diminished, or whose dividends just took a hit due to payments made to owners for repairs...
It cannot be reasonably expected that a multi-billion dollar business will follow a guiding principle to “put the customer first”. Would they get new customers and keep current ones? Probably so however the accountants and attorneys would just point to the actual estimates of costs to be incurred vs. the totally unknown amount of future sales and say: “which one is likely to happen”.
I’d like to see the quality control engineers be victors over the lawyers and “bean counters” but its likely not going to happen. So I will read the forums, grumble about having to change my PTU fluid when it shouldnt have to be done, and “drive on”.
Share this post
Link to post
My 07 Edge just digested a needle bearing in the ptu . I have to order a USA made bearing from China and pay 40$ to ship back to N.Y.
might just buy a new ptu. Can purchase for 695$ delivered to my door
with a 2year warranty.  Then not worry about wear and tear of everything else. Bought the Edge new and love it. I am a victim of profit driven and
very untrustworthy ford dealership. They won't change a taillight bulb
without first charging a 100$ consulting fee to make sure it is really out.
NO JOKE!!! Then a separate charge for bulb and install.
That's why I own my own car lift and garage. It pays for itself.
Share this post
Link to post
the new principles and approaches in development of society are necessary as in this situation the consumer society has exhausted the potential and nothing new can offer, it is way to technogenic degradation, there is no moral vector of development in coil.
Share this post
Link to post
Is that the root cause of the PTU failures?
Share this post
Link to post
ROTFLMAO!
Share this post
Link to post
# phases of a company:
1) Built by Technical people (remember RCA's slogan - Quality goes in before the name goes on!)
2) Run by Accountants (too many MBA's yapping about shareholder value and EBITDA)
3) Shut down by Lawyers.
You pick the Root Cause!
Why Ford can't put a PTU drain in and recommend oil change intervals just amazes me! Most everything else with bearings and oil requires oil changes. (#1 above)
(well maybe not those muffler bearings lol)
But really all it has to do is last to the end of the warranty (#2 above).
They have been building cars for a hundred years. How about learning from previous mistakes - but that might mean admitting you had a problem? (#3 above)
Share this post
Link to post
Between Ford's lifetime fluid debacle and outsourcing the manufacturing of the PTU they simply can't figure it out.  Ford doesn't want to acknowledge nor admit that there is a issue with the PTU design and implementation. I have a co worker (2014 sport) that is on their 2nd PTU replacement. Ford makes it extremely difficult to purchase a replacement unit from the Middle East. Ironically that unit has a built in drain to facilitate changing the fluid.
Ford's solution was to include a drain on the 15-18 edge and going forward they decided to liquid cool the PTU with the 2019 ST.  While this may indicate progress to some, they still insist on using the same fluid.
Share this post
Link to post
1 hour ago, onyxbfly said:
ROTFLMAO!
Its sounded convincing to me !!!!
Share this post
Link to post
13 minutes ago, Brian K said:
I'll bit! What is ROTFLMAO?
Rolling On The Floor Laughing My Ass Off.
Share this post
Link to post
The main reason that Ford cynically continues to ignore problem, and here is not present any responsibility for the product.
Share this post
Link to post
If they acknowledged the problem, they might have to come up with a solution! And then all those with failed PTU's would want Ford to replace them for free!  Accountants would poo-poo that - so history repeats itself - don't correct or acknowledge the problem. Same as the aluminum hood corrosion issue on Mustangs. No problem (to Ford) because it isn't perforation in the warranty period. I wonder how the aluminum F150's will hold up. Will history be repeating itself again maybe???? Is that deja deja vu?
Share this post
Link to post
Some Mazdas use the same PTU and they acknowledged the problem. Mazda extended the warranty. Ironically Ford has not.
Share this post
Link to post
My car of 2008, on it 158000 kilometers while I change liquid in ptu each 7000 km. I do not even dream of guarantee, but I wish to know honestly why it occurs and if I have to replace ptu, I would like to receive the working, full-fledged gear. Or me to hope for Ford guarantee? It is real, Ford will replace to me free of charge ptu by car of 2008?) And who then will buy those ptu which lie at them in warehouse!?)
Edited by EDST777
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
