WWWPerfA_ZN0W Posted January 14, 2022 Report Share Posted January 14, 2022 Welcome. As soon as I saw 2016 and 2.0 and a misfire code, I was ready to cry lol. It may simply be the plugs need changing. ecoboosts eat plugs for lunch, and 60K is a good interval to change them anyway regardless of engine. if a plug change/code reset does not fix the problem, you MAY be looking at a coolant intrusion problem. check the engine label on the right side of the valve cover. post a pic plz. does it say Cleveland or VEP. how is the coolant level? you will want to mark current level with a marker, then follow progress daily/weekly. do you have remaining ford warranty? 1 Quote Link to comment Share on other sites More sharing options...
edkene Posted January 17, 2022 Report Share Posted January 17, 2022 Znow, thanks for the info. I’ll take a look at the valve cover and post a pic - family has been in town and haven’t had a chance to do anything in the past couple of days. I’ll also make sure to keep a closer eye on the coolant level. One thing that I have found is that the engine actually does better when it is cold - it isn’t until after it has warmed over that the misfires occur. From what I’ve been able to read and a couple of mechanics I’ve talked to this could be a symptom of a bad ignition coil - after they warm up they can start having issues but be fine when cold. I’m going to troubleshoot some more tomorrow and see if that is the case. Either way though I’m going to replace the spark plugs since I’ll pull #1 to see how it looks anyway. Quote Link to comment Share on other sites More sharing options...
1004ron Posted January 17, 2022 Report Share Posted January 17, 2022 Quote After start up and the engine has been running for 10-15 seconds, no more rough idle. With the engine off and cooling down, the coolant which is still under some pressure makes its way into the combustion chambers, and then when its started takes some time to displace that coolant - this theory could explain what you describe, but that is speculation, which is also what the couple of mechanics were doing. Before spending money on spark plugs or coils, I'd follow WWWPerfA_ZN0W advice to check your engines place of manufacture - also pulling all plugs and visually inspecting them will also reveal if there's coolant intrusion. 1 Quote Link to comment Share on other sites More sharing options...
edkene Posted January 18, 2022 Report Share Posted January 18, 2022 Thanks 1004 - I’m planning to pull plugs this afternoon. As for the engine manufacturing location, it says Cleveland Engine Plant manufactured on 14 June 2016. looked up the TSB - this could really suck if engine coolant intrusion is the issue. 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted January 18, 2022 Report Share Posted January 18, 2022 24 minutes ago, edkene said: Thanks 1004 - I’m planning to pull plugs this afternoon. As for the engine manufacturing location, it says Cleveland Engine Plant manufactured on 14 June 2016. looked up the TSB - this could really suck if engine coolant intrusion is the issue. With your confirmation that its a Cleveland engine makes it more likely your engine has the coolant intrusion. At least now you are well informed prior contacting Ford - use all the info on hand and stress to them that its a Latent defect and you expect an engine replacement at no cost to you. A work associate/friend is the second owner of one of these, and Ford would not commit to any assistance until they'd opened the engine to diagnose, so he didn't want to risk them declining so he bought a new engine from Ford and had an independent shop install. You didn't respond to the previous question if you had an extended warranty - anyway, the extended warranty has first amount payable by you, which you should reject in this case. 2 Quote Link to comment Share on other sites More sharing options...
my2k2zx2 Posted January 18, 2022 Report Share Posted January 18, 2022 I had this code last year in our 2016 2.0. I replaced the plugs but it did not clear the code. I moved the coils around and the code moved as well. I bought a used coil and the code has yet to return. Quote Link to comment Share on other sites More sharing options...
edkene Posted January 18, 2022 Report Share Posted January 18, 2022 (edited) 1004 - I do not have the extended warranty, and since I’m at 64k miles and over 5 years since I bought it (Nov 2016) this will be *fun* I am still planning on doing a bit more troubleshooting tonight (pulling plugs, swapping around the coils) to ensure that isn’t the issue, but based on the symptoms I’m leaning towards the water intrusion. Hopefully not the case though… I do have an appt at the dealership to have them check it out as well. We’ll see what happens Edited January 18, 2022 by edkene fat fingered stuff Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted January 20, 2022 Report Share Posted January 20, 2022 hopefully will move with the coil/plug and that's that. if you take it to the dealership and they diagnose as a coolant intrusion problem, prob wont be able to get warranty coverage afterwards. BUT you can still possibly get assistance by mediating thru Ford corporte. Quote Link to comment Share on other sites More sharing options...
edkene Posted January 25, 2022 Report Share Posted January 25, 2022 Sorry for the delay in an update but wanted to get everything worked out with Ford first. Took the vehicle in last week and they were backed up on getting to the vehicle - seems the local dealership has been over-booking their techs. First day didn’t get to it, finally got to it the second day. They took a look and suspected a coolant intrusion problem so pressurized the coolant system and left it overnight. The next morning they pulled the plugs (this is the method outlined by the TSB), looked for water intrusion and what do you know, I’ve got a problem. They give me a call and say it isn’t under warranty and it’ll be close to $7k to fix. I then called Ford customer service and explained the issue. Bunch of back and forth later and I’m paying less than 25% of the quoted amount and Ford is covering the rest (thank you for the “latent defect” phrase). Interesting thing I learned - the amount I’m paying and the amount Ford is paying (combined) is less than the quoted amount from the dealership. When I asked the dealership about the discrepancy I was told that my initial quote was the “customer amount” and the new amount that is being paid is the “warranty amount.” I now have the parts on order and will be awaiting the repair. When dealing with Ford they said they would reimburse me for my rental vehicle cost, which is a nice and unexpected addition. On an extra note, when I first took the vehicle in to the dealership I asked if they were seeing a lot of these engines with this issue - the service adviser said that he has been seeing an awful lot of them lately. When I asked what people who are out of warranty have been doing he replied that they have normally been trading them in. I can’t imagine the hit people are taking by trading in a vehicle with a useless engine. 3 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted January 27, 2022 Report Share Posted January 27, 2022 glad Ron's advice helped you out. way to go, Ron! 1 Quote Link to comment Share on other sites More sharing options...
2015Edge2015 Posted February 1, 2022 Report Share Posted February 1, 2022 Have any of you guys just topped off the cooland when needed? How much worse can it get besides the initial rough idle at start up? Does it eventually poor coolant inside the cylinder ? Or just trickles inside forever? Quote Link to comment Share on other sites More sharing options...
2015Edge2015 Posted February 1, 2022 Report Share Posted February 1, 2022 (edited) You need a new engine 100%. The person who sold it to you most likely knew. My 2015 is doing the same. Rough idle at start up. Now a CEL light of cyl 3 misfire. And waterfall noise. Been told it needs a new engine by a shop. So I'm driving it and topping it off until lord knows what's going to happen. Seems like the 2.0l Cleveland engine is faulty from the factory. There's a class action lawsuit going on but haven't heard anything of it sadly. Crossing my fingers ford does the right thing . Im done with ford if not. Next car will be a Japanese suv or full electric. Edited February 1, 2022 by 2015Edge2015 Quote Link to comment Share on other sites More sharing options...
Dulce Posted February 1, 2022 Report Share Posted February 1, 2022 46 minutes ago, 2015Edge2015 said: Have any of you guys just topped off the cooland when needed? How much worse can it get besides the initial rough idle at start up? Does it eventually poor coolant inside the cylinder ? Or just trickles inside forever? I have ?… and it works fine. I have no plans in replacing my engine, just driving it till it drops. I have used the Kseal in coolant and has helped alot. I know its just a bandaid but I will continue to bandaid to keep it running. Note : 2016 Ford Edge current mileage 113k Quote Link to comment Share on other sites More sharing options...
2015Edge2015 Posted February 12, 2022 Report Share Posted February 12, 2022 On 2/1/2022 at 7:57 AM, Dulce said: I have ?… and it works fine. I have no plans in replacing my engine, just driving it till it drops. I have used the Kseal in coolant and has helped alot. I know its just a bandaid but I will continue to bandaid to keep it running. Note : 2016 Ford Edge current mileage 113k Lol! I'm doing the same. Will add water until the engines falls off. I'll probably try kseal. I heard good stuff about blue devil. Just scared to ruin my heater core with all those products! Quote Link to comment Share on other sites More sharing options...
Paul Locke Posted February 16, 2022 Report Share Posted February 16, 2022 I have a 2014 Edge with the 2.0 Ecoboost with 100,000 miles that is leaking coolant into the engine. No Codes or check engine light on. I have seen many posts for the 2015 and newer but none with the first gen. Has anyone have or had this problem? Its at the dealership now waiting for diagnosis. I am glad I have an extended warranty. Quote Link to comment Share on other sites More sharing options...
ChickieSailor Posted February 16, 2022 Report Share Posted February 16, 2022 Hello, We are having trouble with our coolant, we don't know if its leaking or evaporating. Its been to a garage twice with them saying they have found nothing!! We had them drain an replace the coolant because they said there was some problems with a coolant that Ford used that evaporated quickly. We know there is something going on or the coolant would not be disappearing!! HELP has only one else had this problem Coolant pics.eml Quote Link to comment Share on other sites More sharing options...
wandering mind Posted February 16, 2022 Report Share Posted February 16, 2022 (edited) So, I own a 2019 Edge Titanium. I bought it in December of 2018, after FoMoCo bought back my 2017 Escape Titanium with the 1.5L EcoBoost engine. The Escape was a lemon. After the fiasco with the Escape, I bought a 150k mile ESP for 4 years, with a $100 deductible. I'm glad I did. Last summer, my Edge started running rough. I thought I got some bad fuel. About the same time, my coolant level started dropping, so I started topping it off. I knew in the back of my mind it was probably burning coolant, but "I have a VEP engine," I told myself. Try and schedule an appointment with a dealership, no availability within three months! Finally found a dealer with an opening only two weeks out, so I take it. No fault found, $100 deductible. Ugh, coolant is still disappearing, so I reschedule two days later. Next appointment is three weeks out, so I take it. Meanwhile, I'm adding distilled water to my coolant surge tank, in quantities which are making me cringe. But, this is my only vehicle, and it must roll. My O2 sensor is wrecked, as is my catalytic converter and my resonator. Finally, the dealership found the leak. They applied the TSB 20-2234, replaced my O2 sensor, and sent me out the door. My Edge lacks any real acceleration at this point. Dealer says emissions controls warranties are separate from ESP coverage. Okay, gotchya - I'm gonna pay something. This is my only vehicle, and it must roll. Called FoMoCo Corporate, filed a customer request for financial assistance with an issue caused by a failure of one of their covered parts - namely the EGR valve. FoMoCo needs numbers from my repair order, so they can do their back-end calculations. FoMoCo tries to call the dealership. Dealership remains incommunicado for three weeks, not answering their phones nor responding to voicemails. All the dealership had to do is pick up the phone, and read off some digits. Nope, that Black Label dealership is more like a No Label dealership, service-wise. Finally, after three weeks, FoMoCo gets the numbers. They offer to pay 75% of the catalytic, while I pay 25%. Deal, let's do this, but they should be paying 100% in my eyes. Whatever, let's just get this done. But I ain't goin' back to that one dealership, they can't even answer their phones. I hope they suffer, somehow... Find another nearby dealership with a loaner vehicle. Catalytic gets replaced, as we don't yet know the resonator is plugged up. I pick up my Edge, and as I try to drive away I notice it still lacks power. Disheartened, I babied it home, and returned the following morning. Also, a new clunking sound exists when I accelerate. Tech diags the next issue as the resonator, and an exhaust hangar as having slipped off. FoMoCo offers to pay 75% for the resonator, and I pay 25%. Deal, let's do this. I just want it done... BUT as the tech was backing out of the service bay after diagnosing the resonator as being plugged, my Edge stumbled and tossed a code. You know how people always complain their vehicle NEVER acts up for the tech? Well, mine finally did just that... Service rep calls to ask, have I had the EGR replaced yet. I told her, that is what proceeded all this fun. Service rep tells me about the tech diagnosing my vehicle with a misfire, and that he was troubleshooting it, and says she'll have to get back to me. I later hear back from FoMoCo via email. I need a new engine. Surely autocorrect changed EGR to Engine for her, right? I call the dealer - nope, I need a new engine. The tech has scoped pictures of coolant in my cylinders. So I'm all like, "ok, how much is this gonna cost me, $100?" Service rep says she doesn't know yet, and says she needs to run my VIN. I'm all like, "if it's $100, let's do this already." I could tell the service rep didn't like this conversation, presumably because it was possibly gonna cost me a lot. She eventually came back with, "yes sir, it looks like it'll be $100." Neither the service rep, nor FoMoCo, seemed to know I had an ESP for my Edge. So here I sit, still without my vehicle. I've been without it effectively since January 3rd or 5th, I forget. At this point, the resonator has arrived, the catalytic is installed, the new long block engine to replace my verified VEP engine has arrived, and we're only waiting to hear from the ESP folks that Wear & Tear can begin their work (essentially waiting for the thumbs up that ESP will pay their part). Been in this waiting pattern for almost two weeks... So, how many people are out there with a VEP 2.0L EcoBoost engine, and needed a replacement long block due to coolant intrusion issues at the EGR? Also, how many out there can say their last TWO Ford vehicles both needed replacement long blocks ... and that at least one of those TWO vehicles (to date, anyways), was bought back by FoMoCo as a lemon? But I'll be honest. Aside from all the above EGR-related troubles, that vehicle has done well. It has been a dream to pilot, as evidenced by the 102,517 miles currently on the odo... Edited February 16, 2022 by wandering mind 2 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted February 17, 2022 Report Share Posted February 17, 2022 interesting read. really shouldn't have to have paid anything but a deductible, i agree. and yes, you are not the only one to have had 2 vehicles with coolant issues and similar tales to yours, lol. luckily you have a 2019, so probably avoid the cracked flexplate issue that showed up on the 2015-2018 MYs. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted February 17, 2022 Report Share Posted February 17, 2022 @ChickieSailor i hope you have an honest dealership. but first, we need to know MY, engine, mileage and all the good stuff to give you a targeted response. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted February 21, 2022 Report Share Posted February 21, 2022 Ford coolant doesnt evaporate quickly. My 09 mkx doesn’t use any to speak of between oil changes. (3.5 Cyclone). Hope your dealer found the problem, my initial guess would center in on the water pump failing (if outer seal is leaking, its dumping coolant overboard through weap holes. If inner seal leaks, it dumps coolant into oil pan. They can test for water in oil to confirm). Could also be a hose leaking or head gasket. Coolant in oil will turn the oil a tanish cream color. Read this as well. https://fordauthority.com/2020/12/new-lawsuit-targets-ford-ecoboost-four-cylinder-coolant-leaks/ Quote Link to comment Share on other sites More sharing options...
2015Edge2015 Posted March 11, 2022 Report Share Posted March 11, 2022 (edited) On 1/25/2022 at 2:36 PM, edkene said: Sorry for the delay in an update but wanted to get everything worked out with Ford first. Took the vehicle in last week and they were backed up on getting to the vehicle - seems the local dealership has been over-booking their techs. First day didn’t get to it, finally got to it the second day. They took a look and suspected a coolant intrusion problem so pressurized the coolant system and left it overnight. The next morning they pulled the plugs (this is the method outlined by the TSB), looked for water intrusion and what do you know, I’ve got a problem. They give me a call and say it isn’t under warranty and it’ll be close to $7k to fix. I then called Ford customer service and explained the issue. Bunch of back and forth later and I’m paying less than 25% of the quoted amount and Ford is covering the rest (thank you for the “latent defect” phrase). Interesting thing I learned - the amount I’m paying and the amount Ford is paying (combined) is less than the quoted amount from the dealership. When I asked the dealership about the discrepancy I was told that my initial quote was the “customer amount” and the new amount that is being paid is the “warranty amount.” I now have the parts on order and will be awaiting the repair. When dealing with Ford they said they would reimburse me for my rental vehicle cost, which is a nice and unexpected addition. On an extra note, when I first took the vehicle in to the dealership I asked if they were seeing a lot of these engines with this issue - the service adviser said that he has been seeing an awful lot of them lately. When I asked what people who are out of warranty have been doing he replied that they have normally been trading them in. I can’t imagine the hit people are taking by trading in a vehicle with a useless engine. I'm in the same boat. Coolant intrusion. Not sure how to handle this since trading it in is just impossible. CeL light is on permanently and eats cooland rather quick. Top it off every 4 days or so. My question for you is... did you have any kind of warranty on it? Or were you 100% out of any warranty? I'm asking since the "latent defect" phrase made Ford pay for some of the cost. Thinking of doing the same but I'm 100% in the no extended warranty boat and think it would be hard to get them to help me out. 7 to 8k is just not doable and feel as this should be treated like the 1.6 liter motor settlement everyone got due to the very same nature of the problem. Any advice would be appreciated. I like this car alot. Oh btw, I have 156k miles. Edited March 11, 2022 by 2015Edge2015 Quote Link to comment Share on other sites More sharing options...
edkene Posted March 12, 2022 Report Share Posted March 12, 2022 Hey 2015, I was 100% out of warranty. I was at 64,000 miles and 5 years and two months of ownership (warranty is 60,000 miles or 5 years). Having 156k miles may be a bit more difficult since you are well past the 60k mark - I’m not sure. Never hurts to give Ford a call, however. The largest issue you’re g oing to run into is that Ford will want you to have taken it to a Ford dealership. When I called the Ford customer service people they asked which Ford dealership it was at so they could call the service rep. So you’ll have to get an appointment at a Ford dealership and be willing to leave the vehicle with them at least overnight so they can do the leak down test (they pressurize the coolant system, leave it for a few hours, then come back and check to see if the pressure has gone down. If it has they then pull the spark plugs and look in the cylinders for water intrusion). Once they have verified that is indeed the issue then you can start the process rolling with Ford. As an additional note, to anyone who has this problem, be careful with the dealership. When I was told my vehicle was complete and I went to pick it up they tried to charge me an extra ~$550 for “one time use parts.” They said the parts were parts that could not be re-used and had to be replaced when they did the engine. They told me that Ford wasn’t going to pay for them and so I would have to. I refused and said that wasn’t part of the deal with Ford. Finally Ford corporate decided to pay for the extra amount since we (corporate Ford) and I had an agreement in writing as to what my portion of the cost would be. When the stealership dealership was trying to get me to pay the extra amount I kept asking questions about what exactly all the parts were for, and the service rep kept giving me the runaround. I had a suspicion that the extra parts were not factored into the initial price they gave to Ford for repairing the vehicle, and I believe I am right. After I got the vehicle back with the itemized receipt, I went and looked at all of the parts the service rep told me were “one time use parts.” I cross referenced those to the Technical Service Bulletin regarding this engine issue, and all of those parts were listed in the TSB as items that would need to be replaced as part of the repair for this issue. What this told me is that my suspicion was correct - the dealership did not quote those extra parts to Ford. I’m not sure if they guy forgot and then was trying to cover his butt by getting me to pay for the extra parts, or if they were trying to make some extra money due to the additional markup they would get by selling the parts to me vice Ford. Either way, I found the situation extremely shady. One last thing 2015 - when talking to Ford get them to commit to paying for your rental car (if they offer to help). Ford reimbursed me for the cost of my rental vehicle while my vehicle was being repaired. They ended up sending me a prepaid visa gift card for the amount of the total cost of the rental. 1 Quote Link to comment Share on other sites More sharing options...
2015Edge2015 Posted March 12, 2022 Report Share Posted March 12, 2022 (edited) 16 hours ago, edkene said: Hey 2015, I was 100% out of warranty. I was at 64,000 miles and 5 years and two months of ownership (warranty is 60,000 miles or 5 years). Thanks for the reply. Good information! And yeah... 156k miles will probably not be in my favor but knowing these engines are almost all failing... might still help someone us with higher mileage. I ended up driving the car to the dealer since a rough IDLE came today around mid day. Would not go away like when at start up with the coolant in it. Even tried changing #3 plug in which my scanner pointed as misfiring. But it didn't fix it... rough idle. So just stopped there and took it to the dealer for them to diagnose it. Well ... let's see what happens now. Edited March 12, 2022 by 2015Edge2015 Quote Link to comment Share on other sites More sharing options...
2015Edge2015 Posted March 23, 2022 Report Share Posted March 23, 2022 Just got quoted 6978.00$ to replace to a long block. hating this car with all the issues. For those that did it, did you go to dealer or independant shop? And how much? I've seen people say 5200$ to 8000$. Just depends where you are. So maybe post location and cost. I'm facing this atm. Thinking of doing it since it's far cheaper than getting another car loan. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted March 23, 2022 Report Share Posted March 23, 2022 9 hours ago, 2015Edge2015 said: Just got quoted 6978.00$ to replace to a long block. hating this car with all the issues. For those that did it, did you go to dealer or independant shop? And how much? I've seen people say 5200$ to 8000$. Just depends where you are. So maybe post location and cost. I'm facing this atm. Thinking of doing it since it's far cheaper than getting another car loan. @2015Edge2015 what mileage on your vehicle? sorry if i missed it in this thread ... if under 100K, or if just out of the powertrain warranty period, you can work with ford corporate to at least get part of the cost reimbursed. there might be law firms out there that will mediate for you as well. Quote Link to comment Share on other sites More sharing options...
