theoldwizard1
My theory on why lug nuts fail
Well it looks like I will be replacing most of my lug nuts on my 2016 Edge.  I have done all of my own tires rotation for the past 5 years and managed to only bugger up 2 nuts.  I am using a Sunex flip lug nut set, which I recommend.
The stock/OEM lug nuts require a 21mm socket.  I know that some of the aftermarket use 22mm.  A 7/8" socket will fit an OEM lug nut (7/8" = 0.875" ; 22mm = 0.866" ; 21mm =  0.826"), but I guarantee they will mess up the chrome cap !
Now here is the crazy thing  !  The Edge lug nuts (ACPZ-1012-M) and the F150 lug nut (ACPZ-1012-B) look almost identical.  Same threads, same socket
Edge  F150
But $4.18 vs $0.90
Edited by theoldwizard1
Share this post
Link to post
I guess it depends on the F150 wheels, but I thought most F150s used the large seat like the Edge lugnuts on the left.
I picked up some Gorilla 61148CX to use when my factory Edge lugnut's caps start rusting and falling off.  They are little taller and stick out past the wheel a bit more.
http://www.gorilla-auto.com/lug-nuts-page-09
24 pack
https://www.ebay.com/itm/334151861559?epid=1433548720&hash=item4dcd00c537:g:5zIAAOSwe31hRNk6
20 pack
https://www.ebay.com/itm/181391077645?epid=622863125&hash=item2a3bc0310d:g:rJ0AAOSw77RiYbgl
Share this post
Link to post
The "seat"  ( cone shaped taper at the bottom) is an "industry standard" 60° on both.  I am not sure why the F150 lug nuts have that extra 1/4" - 1/2" on material above that.
Share this post
Link to post
I was charged for replacing 3 lug nuts because they could not be reused.  When I got home, I discovered that more lugs nuts were damaged to the point that the socket that came with the car could not be used.
The dealer agreed to replace 4 additional lug nuts at no charge.
Share this post
Link to post
The shinny outer shell is aluminum, and the dealerships use a pneumatic impact wrench to remove and install the lug nuts, which distorts and stretches the aluminum.
My dealership using this method also chipped my wheels - as the lug nuts come off the sockets swings around a hammers the wheels.
When I confronted the dealership about the swollen lug nuts and damage to my wheels, he responded that they use torque sticks - well that only helps not to over torque the nuts, the impact action still destroys the soft aluminum shell.
He ordered a full set at no cost to me.
BTW, there is existing threads on this topic.
Edited by 1004ron
Share this post
Link to post
If you're looking for a quality lug nut set, I recommend checking out wheelssize.com. They have a great selection of lug nuts to choose from, and they're sure to have something that will fit your needs.
Edited by 1004ron
Share this post
Link to post
I recently found that there is a Ford Performance part (M-1012-M - link) that includes 5 lug nuts for the Mustang (which has the same lug nuts as the 2015+ Edge) for a retail price of USD 15. Searching online I find it for even less (eBay listing for 4 sets - Levittown Ford Parts). Making each lug cost nearly half as much as buying them individually. I ordered the set from the eBay listing and will update once received & installed to confirm. I had previously installed black lug nuts from Veritek (link to thread about them) however they quickly started to show rust after a few wheel removals/installations.
Share this post
Link to post
Help....What size hex socket fits on the bare wheel nut? I managed to rip out one of my messed up chrome caps (basically cut it up into little pieces, still some left in there but I think enough to get a deep socket on) to expose the steel wheel  nut, but nothing I have seems to fit. Is it 20mm?
Share this post
Link to post
It's 21mm with the aluminum skin, so estimate it around 18 or 19mm without the skin.
Share this post
Link to post
probably about a 20mm, but not sure.
19mm = 3/4" (effectively) so if 19 is too small and 20mm is too big, you could try 13/16" or 7/8"
Share this post
Link to post
Follow up, I just received my order and I can confirm they are the same lug nuts for the Ford Edge. So if you need a set of 5 or more OEM lug nuts, buy the Ford Performance part M-1012-M.
  • Like 3
  • Thanks 1
Share this post
Link to post
I need these! Poor guys at the tyre shop struggled to get the nuts off, they are warped so they get stuck on the wrench.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
