Zand Report post Posted January 5 Had a problem with Forscan which i did factory reset and it took away my Traction control in driver assist menu. I am wondering which module/ number is it so i can fix it? IMG_9181.HEIC Share this post Link to post Share on other sites
omar302 Report post Posted January 5 Try the IPC module. Share this post Link to post Share on other sites
1004ron Report post Posted January 5 (edited) @Zand Zadyen Frank please add your Model & Year to your profile signature. headlamp assembly - Accessories & Modifications - Ford Edge Forum Edited January 5 by 1004ron Share this post Link to post Share on other sites
dabangsta Report post Posted January 5 It isn't an option in my Driver Assist list in my 2019 SEL. I have a button near the light switch to temporarily disable it (it will be enabled next start up). If you have an ST then you can set Sport mode. Share this post Link to post Share on other sites
Zand Report post Posted January 5 4 hours ago, omar302 said: Try the IPC module. I’ve looked.. Maybe i missed it but I’ll look again! Share this post Link to post Share on other sites
Zand Report post Posted January 5 2 hours ago, dabangsta said: It isn't an option in my Driver Assist list in my 2019 SEL. I have a button near the light switch to temporarily disable it (it will be enabled next start up). If you have an ST then you can set Sport mode. I have a 16 sport. 1 Share this post Link to post Share on other sites
dabangsta Report post Posted January 5 2016 manual shows that it should be there (Traction Control in Driver Assist menu), and I don't think 2016 got the Sport mode for ESC. Could you shut it off permanently in this menu, or is it still temporary until enabled in menu or next time the vehicle is started? Share this post Link to post Share on other sites
Zand Report post Posted January 5 3 hours ago, dabangsta said: 2016 manual shows that it should be there (Traction Control in Driver Assist menu), and I don't think 2016 got the Sport mode for ESC. Could you shut it off permanently in this menu, or is it still temporary until enabled in menu or next time the vehicle is started? I’ve turn the vehicle off about 3-4 times now and it’s not showing up still… Is it possible to get it back in the menu? 1 Share this post Link to post Share on other sites
1004ron Report post Posted January 5 1 hour ago, Zand said: I’ve turn the vehicle off about 3-4 times now and it’s not showing up still… Is it possible to get it back in the menu? Please add your vehicle details to your profile signature - Settings - Ford Edge Forum Share this post Link to post Share on other sites
Zand Report post Posted January 6 1 hour ago, 1004ron said: Please add your vehicle details to your profile signature - Settings - Ford Edge Forum did that work now? 1 Share this post Link to post Share on other sites
