Apparantly the driver's side air temp blend damper has failed(low temperature in vent air). Anyone know how to access the air box? Dealer wants $1400 to fix it. Thanks
I have a 2012 Edge LTD with the dual zone climate with 106k miles. I also had the issue of blowing hotter than hot air on the driver's side, and cold on the passenger's with the AC on Max. Thanks to this thread, I was able to try the recommendations here. I unplugged the green connector with the car off, plugged back in and turned car on. Turned on AC, still the same result. Next, turned car off, then unplugged connector, and started car. Turned AC on, no changes. Turned AC off, car is stil
